Ir para o conteúdo principal
Insignia NS-CLOPP2 Screen Replacement
O que você precisa
  1. Insignia NS-CLOPP2 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
    Pergunte ao FixBot
    Comentar
  2. Insignia NS-CLOPP2 Screen Replacement: passo 2, imagem 1 %32
    • Begin to pry the front screen off gently with a Jimmy tool made by Ifixit.
    Pergunte ao FixBot
    Comentar
  3. Insignia NS-CLOPP2 Screen Replacement: passo 3, imagem 1 %32
    • Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
    Pergunte ao FixBot
    Comentar
  4. Insignia NS-CLOPP2 Screen Replacement: passo 4, imagem 1 %32
    • Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
    • To reassemble your device, follow these instructions in reverse order.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Marist, Team 1-1, Laflen Spring 2015 Membro de Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 39
Ao todo: 540
