Ir para o conteúdo principal
Insignia NS-B4111 Motherboard Replacement
O que você precisa
  1. Insignia NS-B4111 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Insignia NS-B4111 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Motherboard Replacement: passo 2, imagem 1 %32 Insignia NS-B4111 Motherboard Replacement: passo 2, imagem 2 %32
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Motherboard Replacement, Casing: passo 3, imagem 1 %32
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  4. Insignia NS-B4111 Motherboard Replacement: passo 4, imagem 1 %32 Insignia NS-B4111 Motherboard Replacement: passo 4, imagem 2 %32
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  5. Insignia NS-B4111 Motherboard Replacement, Antenna Base: passo 5, imagem 1 %32 Insignia NS-B4111 Motherboard Replacement, Antenna Base: passo 5, imagem 2 %32
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
  6. Insignia NS-B4111 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Unscrew the four 12.5mm screws with the Phillips PH1 Screwdriver.
    • Unscrew the one 10mm long screw with the Phillips PH1 Screwdriver.
  7. Insignia NS-B4111 Motherboard Replacement: passo 7, imagem 1 %32
    • Orient the device so that the back is facing you.
    • Unplug the six pin male/female header from its socket on the motherboard. The wires on the header are these colors: burgundy, red, orange, yellow, green, and blue.
    • Use a tweezer if you find it hard to pull the header out with your fingers.
    • Gently pull out the ribbon cable from its socket on the motherboard.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the wires the wrong way may short circuit the board.
  8. Insignia NS-B4111 Motherboard Replacement: passo 8, imagem 1 %32
    • Rotate the device so that the front is facing you.
    • Unplug the four pin header from its socket on the motherboard. The wires on the header are these colors: brown, red, orange, and yellow.
    • Use a tweezer if you find it hard to pull this header out with your fingers.
    • Gently pull out the ribbon cable from its socket.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the base the wrong way may short circuit the board.
  9. Insignia NS-B4111 Motherboard Replacement: passo 9, imagem 1 %32
    • Pull out the two pin header from its socket on the motherboard. The wires on this header are black and white.
    • Use a tweezer if you find it hard to pull this cable out with your fingers.
  10. Insignia NS-B4111 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Scrape off the glue from the black wire with the blue plastic opening tool.
  11. Insignia NS-B4111 Motherboard Replacement: passo 11, imagem 1 %32 Insignia NS-B4111 Motherboard Replacement: passo 11, imagem 2 %32
    • Desolder the one black, one red, and two blue wires. If you need help soldering, see this guide.
Conclusão
Kristin Yoshioka
Membro desde: 09/21/16
984 Reputação
Autoria de 9 guias
Equipe
UC Davis, Team 1-5, Oliver Fall 2016 Membro de UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 1,295
