Ir para o conteúdo principal
Insignia NS-B2110 Transformer Replacement
O que você precisa
  1. Insignia NS-B2110 Transformer Replacement, Battery: passo 1, imagem 1 %32 Insignia NS-B2110 Transformer Replacement, Battery: passo 1, imagem 2 %32
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Transformer Replacement: passo 2, imagem 1 %32 Insignia NS-B2110 Transformer Replacement: passo 2, imagem 2 %32
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Insignia NS-B2110 Transformer Replacement, Bottom Panel: passo 3, imagem 1 %32
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Insignia NS-B2110 Transformer Replacement: passo 4, imagem 1 %32 Insignia NS-B2110 Transformer Replacement: passo 4, imagem 2 %32
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Insignia NS-B2110 Transformer Replacement: passo 5, imagem 1 %32 Insignia NS-B2110 Transformer Replacement: passo 5, imagem 2 %32 Insignia NS-B2110 Transformer Replacement: passo 5, imagem 3 %32
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  6. Insignia NS-B2110 Transformer Replacement, Transformer: passo 6, imagem 1 %32 Insignia NS-B2110 Transformer Replacement, Transformer: passo 6, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove two 4mm screws from the transformer box.
    • Remove the transformer and set it to the side.
  7. Insignia NS-B2110 Transformer Replacement: passo 7, imagem 1 %32
    • Remove the solder connecting the two yellow wires to the green quarter-circle board.
  8. Insignia NS-B2110 Transformer Replacement: passo 8, imagem 1 %32 Insignia NS-B2110 Transformer Replacement: passo 8, imagem 2 %32 Insignia NS-B2110 Transformer Replacement: passo 8, imagem 3 %32
    • There will be a strip of electrical tape securing the converter. Use scissors to carefully remove this tape.
    • Use a Phillips #2 screwdriver to remove two 4mm screws from the converter.
    • Remove the converter. There will be a plastic casing that slides off; set this aside.
  9. Insignia NS-B2110 Transformer Replacement: passo 9, imagem 1 %32
    • Remover the solder from the red and yellow wires on the converter.
Conclusão
Jacob Phillips
Membro desde: 10/14/13
313 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-31, Amido Fall 2013 Membro de Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 311
