Ir para o conteúdo principal
Insignia Flex 10.1 NS-P16AT10 Battery Replacement
O que você precisa
  1. Insignia Flex 10.1 NS-P16AT10 Battery Replacement, Battery: passo 1, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your device is off and not connected to any power sources to avoid injury
    • Use a plastic opening tool to remove the rear panel from the front case.
    • Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
    • Work the tool around the perimeter of the device until the front and rear panels become separate.
    • The volume rocker and power button will become free from the device when the front and rear panels are separated from each other. Do not worry. These pieces are easily put back into place when reassembling the tablet.
  2. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 2, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to flip the ribbon connector up in order to free the ribbon cable from the motherboard.
  3. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 3, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 3, imagem 2 %32 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 3, imagem 3 %32
    • Free the battery from the motherboard by desoldering the red, white, and black connections one by one.
    • For soldering instructions, visit this guide.
    • Remove the soldering tip immediately once the wire has become free. Too much heat can damage the motherboard.
  4. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 4, imagem 1 %32
    • Peel the black tape up that is attached to the battery and front case.
  5. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 5, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to remove the battery from the front case.
    • Place the plastic opening tool between the battery and front case. Work the tool around the perimeter of the battery until the battery is free.
    • Do not bend or puncture the battery, or the battery will leak.
  6. Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 6, imagem 1 %32 Insignia Flex 10.1 NS-P16AT10 Battery Replacement: passo 6, imagem 2 %32
    • The battery is now removed from the device. Replace the battery.
Conclusão
Morgan Kidd
Membro desde: 10/10/16
419 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 12-3, Bennett Fall 2016 Membro de Texas Tech, Team 12-3, Bennett Fall 2016
TTU-BENNETT-F16S12G3
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 729
