O que você precisa
Position the tablet with the top edge by the camera facing down.
Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
Using the plastic opening tool, lift up the black retaining flap that secures the camera ZIF (zero insertion force) ribbon connector to the motherboard
The motherboard is now free from the device and can now be replaced. To reassemble your device, follow these instructions in reverse order.
3 outras pessoas executaram este guia.
