Ir para o conteúdo principal
Infant Optics DXR-8 Charging Port Replacement
O que você precisa
  1. Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: passo 1, imagem 1 %32 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: passo 1, imagem 2 %32 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: passo 1, imagem 3 %32
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Charging Port Replacement: passo 2, imagem 1 %32 Infant Optics DXR-8 Charging Port Replacement: passo 2, imagem 2 %32 Infant Optics DXR-8 Charging Port Replacement: passo 2, imagem 3 %32
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Charging Port Replacement: passo 3, imagem 1 %32 Infant Optics DXR-8 Charging Port Replacement: passo 3, imagem 2 %32 Infant Optics DXR-8 Charging Port Replacement: passo 3, imagem 3 %32
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Charging Port Replacement, Charging Port: passo 4, imagem 1 %32 Infant Optics DXR-8 Charging Port Replacement, Charging Port: passo 4, imagem 2 %32
    • Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
  5. Infant Optics DXR-8 Charging Port Replacement: passo 5, imagem 1 %32 Infant Optics DXR-8 Charging Port Replacement: passo 5, imagem 2 %32
  6. Infant Optics DXR-8 Charging Port Replacement: passo 6, imagem 1 %32
    • Remove the old charging port and solder the new one in place.
    • After removing the old port make sure to clean ALL the excess solder from the though holes.
    • Add a little solder to each of the 5 surface mount pads on the PCB before putting the new port on. Its a bit of a tight fit between the screen and the port so getting an iron and solder positioned correctly without blobbing or bridging is hard.
    • Place the new port on and make sure the large pins fit though the holes (the won't go all the way though)
    • Solder one of the though holes to start (if you mess up the surface pads its easier to get back off if you only have to melt one structural connection)
    • Solder the 5 surface mount pads. If the port didn't sit all the way down to the PCB you can push each pin down with the iron onto the pad and into the solder. (pre adding solder to those pads helps with this)
    • Finishing soldering the though hole pins.
  7. Infant Optics DXR-8 Charging Port Replacement: passo 7, imagem 1 %32
    • Flip the unit over to ensure a correct fitment.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 13-4, Banghart Winter 2017 Membro de Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Membros
Autoria de 4 guias
3Comentários do guia
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
John Lynch - Responder Compartilhar
The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
Donovan Zusalim - Compartilhar
Worth pointing out that this guide shows an older version of the DXR-8 (2014 printed on the PCB) where the microUSB port uses through-hole leads to connect to the board. Mine is a few years newer and the port was surface-mounted, which requires more skill and care to replace. I ended up ordering the part myself and taking it to a repair shop for them to do the soldering.
Danny Conrad - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 81
Ao todo: 7,219
