Ir para o conteúdo principal
Infant Optics DXR-8 Camera Motherboard Replacement
O que você precisa
  1. Infant Optics DXR-8 Camera Motherboard Replacement, Infant Optics DXR-8 Camera Disassembly: passo 1, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement, Infant Optics DXR-8 Camera Disassembly: passo 1, imagem 2 %32
    • Position the camera with bottom facing toward you.
    • Using the plastic opening tool, remove all four rubber ends from the bottom of the camera.
  2. Infant Optics DXR-8 Camera Motherboard Replacement: passo 2, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the four 4 mm screws beneath rubber ends using the Phillips #00 screwdriver.
  3. Infant Optics DXR-8 Camera Motherboard Replacement: passo 3, imagem 1 %32
    • Open the bottom of the camera to reveal the circuit board and speaker.
  4. Infant Optics DXR-8 Camera Motherboard Replacement, Camera Motherboard: passo 4, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement, Camera Motherboard: passo 4, imagem 2 %32
    • Disconnect the speaker wire and set the base plate to the side.
    • Remove the tan power selector.
  5. Infant Optics DXR-8 Camera Motherboard Replacement: passo 5, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 5, imagem 2 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using fine tip tweezers, disconnect the four electrical connectors on the board surface.
    • The connectors are secured with an adhesive that may need to be gently scraped off.
    • Using a Phillips #00 screwdriver, remove the two 5mm screws on either side of the motor.
    • Lift the motor from the board and set it to the side.
    • Using a Phillips #00 screwdriver, remove the 6mm screw from the antenna housing.
  6. Infant Optics DXR-8 Camera Motherboard Replacement: passo 6, imagem 1 %32
    • Lift the circuit board off the four locating pegs. Avoid lifting one side too much as it slides up the pegs to allow for smooth removal.
    • Feed the connectors through the slot in the center of the board.
  7. Infant Optics DXR-8 Camera Motherboard Replacement: passo 7, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 7, imagem 2 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 7, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the four 6mm screws in the gear. Take note of the location of the tab on the gear for reassembly.
    • Feed the electrical connectors through the center hole of the gear and base housing.
  8. Infant Optics DXR-8 Camera Motherboard Replacement: passo 8, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 8, imagem 2 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 8, imagem 3 %32
    • Using a plastic opening tool, pry the tan housing coupler and face plate off.
  9. Infant Optics DXR-8 Camera Motherboard Replacement: passo 9, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 9, imagem 2 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 9, imagem 3 %32
    • Gently but firmly split the camera housing. Use a plastic opening tool to assist in splitting apart the camera body if needed.
  10. Infant Optics DXR-8 Camera Motherboard Replacement: passo 10, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 10, imagem 2 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 10, imagem 3 %32
    • Using a Phillips #000 screwdriver, remove the 7.5mm screw holding the left camera leg to the camera body.
    • Feed the electrical connectors through the hole in the body of the leg.
    • Feed the electrical connectors through the hole in the camera body.
    • Attempting to pull the wires through without separating the two pieces can cause damage to the connectors.
  11. Infant Optics DXR-8 Camera Motherboard Replacement: passo 11, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 11, imagem 2 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 11, imagem 3 %32
    • Using fine tip tweezers, disconnect the three electrical connectors from the motherboard.
    • Using a Phillips #000 screwdriver, remove the two 5mm screws holding the camera motherboard in place.
    • Lift the camera motherboard off the locating pegs.
  12. Infant Optics DXR-8 Camera Motherboard Replacement: passo 12, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 12, imagem 2 %32
    • Using fine tip tweezers, disconnect the yaw motor electrical connector from the camera motherboard.
    • Carefully unlock the black ribbon cable locks to release the camera ribbon cable. Use the fine tip tweezers if necessary.
  13. Infant Optics DXR-8 Camera Motherboard Replacement: passo 13, imagem 1 %32 Infant Optics DXR-8 Camera Motherboard Replacement: passo 13, imagem 2 %32
    • Using a soldering iron and desoldering braid, desolder the three limit switch wires from the camera motherboard.
    • Flip the board over.
    • Using the soldering iron and desoldering braid, desolder the antenna from the camera motherboard.
    • For more information on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
    • Use caution while operating the soldering iron. Multiple small components are mounted near the wire connections that could be damaged by the hot iron.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
We've had the microphone go in and out. Resetting doesn't work anymore, so I tore into it tonight (wish I would've seen this guide before, didn't think the connector glue would be as strong as it was). I did not make it past the first circuit board. What I couldn't figure out is where the microphone is.
I believe it's the enclosure with cord coming out with the antenna, soldered straight into the board. It could also be the temperature sensor. Thankfully pulling it apart and reassembling it got the microphone working again, but you can bet your bottom dollar it'll go out again.
Thanks for the guide, it was very helpful seeing what else is in there.
Hough Ganis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 35
Duração total: 2,055
