Ir para o conteúdo principal
Infant Optics DXR-8 Battery Replacement
    1. Infant Optics DXR-8 Battery  Replacement, Battery: passo 1, imagem 1 %32 Infant Optics DXR-8 Battery  Replacement, Battery: passo 1, imagem 2 %32 Infant Optics DXR-8 Battery  Replacement, Battery: passo 1, imagem 3 %32
      • Begin by holding the Monitor so that the backside is flipped up. This is where your battery is located.
      • Slide the battery panel downwards to detach it completely. The battery should be completely visible.
      Pergunte ao FixBot
      Comentar
    2. Infant Optics DXR-8 Battery  Replacement: passo 2, imagem 1 %32 Infant Optics DXR-8 Battery  Replacement: passo 2, imagem 2 %32 Infant Optics DXR-8 Battery  Replacement: passo 2, imagem 3 %32
      • Now that your battery is exposed, begin to take the battery out. The only thing keeping the battery in the battery port should be the plug.
      • Now unplug the battery from the battery port. The plug is small so be careful locating it.
      • The battery and plug should be completely out of the battery port.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order
4 outras pessoas executaram este guia.
Katelynn Dinius
Membro desde: 01/31/17
269 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-4, Banghart Winter 2017 Membro de Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 62
Ao todo: 12,548
