Ir para o conteúdo principal
India Mark II Water Tank Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. India Mark II Water Tank Replacement, Cover Plate: passo 1, imagem 1 %32
    • Use a wrench to remove the bolt on the top of the cover plate.
    • When replacing the cover plate, this bolt only needs to be hand tight.
  2. India Mark II Water Tank Replacement: passo 2, imagem 1 %32
    • Remove the top cover by pulling it straight off the pump.
    • Store the top cover in a sanitary place, preferably above ground, to prevent contamination.
  3. India Mark II Water Tank Replacement, Head Section: passo 3, imagem 1 %32 India Mark II Water Tank Replacement, Head Section: passo 3, imagem 2 %32 India Mark II Water Tank Replacement, Head Section: passo 3, imagem 3 %32
    • Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
    • Place the spacer around the pump rod and under the chain attachment point.
    • Make sure the spacer is beveled side down, and flat side up.
    • Lift the pump lever until there is no tension in the chain and hold it in this position.
  4. India Mark II Water Tank Replacement: passo 4, imagem 1 %32 India Mark II Water Tank Replacement: passo 4, imagem 2 %32
    • Remove the bolt connecting the chain to the pump handle.
    • Remove the chain from the handle.
  5. India Mark II Water Tank Replacement: passo 5, imagem 1 %32 India Mark II Water Tank Replacement: passo 5, imagem 2 %32 India Mark II Water Tank Replacement: passo 5, imagem 3 %32
    • There are 4 bolts securing the head section to the water tank, located at the corners of head section base.
    • Continue supporting the pump handle so the pump head doesn't fall off when all the bolts are removed.
    • Remove the 4 bolts on the base of the water tank.
  6. India Mark II Water Tank Replacement: passo 6, imagem 1 %32
    • Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
  7. India Mark II Water Tank Replacement, Water Tank: passo 7, imagem 1 %32 India Mark II Water Tank Replacement, Water Tank: passo 7, imagem 2 %32 India Mark II Water Tank Replacement, Water Tank: passo 7, imagem 3 %32
    • Lift the plunger assembly and separator plate and place a rod clamp below the separator plate.
    • Tighten the rod clamp and gently set the separator plate on top of it.
    • Remove the spacer.
  8. India Mark II Water Tank Replacement: passo 8, imagem 1 %32 India Mark II Water Tank Replacement: passo 8, imagem 2 %32 India Mark II Water Tank Replacement: passo 8, imagem 3 %32
    • Hold the rod clamp steady while removing the chain from the pump rod. Check the chain for signs of damage.
    • Extend the chain sideways and use it as a lever as demonstrated in the first picture.
    • Remove the lock nut by turning it counterclockwise.
    • Remove the separator plate.
  9. India Mark II Water Tank Replacement: passo 9, imagem 1 %32 India Mark II Water Tank Replacement: passo 9, imagem 2 %32
    • Reinstall the lock nut.
    • Install a T-handle, screwing it down against the lock nut.
  10. India Mark II Water Tank Replacement: passo 10, imagem 1 %32 India Mark II Water Tank Replacement: passo 10, imagem 2 %32
    • Lift up on the T-handle to take pressure off the rod clamp.
    • Remove the rod clamp and slowly lower the T-handle.
    • The pump rod will rest on the end cap, located below the cylinder of the pump. It is important to lower the T-handle slowly to prevent damage to the pump.
  11. India Mark II Water Tank Replacement: passo 11, imagem 1 %32
    • There are 4 bolts securing the water tank to the pump base. They are located at the bottom corners of the water tank.
  12. India Mark II Water Tank Replacement: passo 12, imagem 1 %32 India Mark II Water Tank Replacement: passo 12, imagem 2 %32 India Mark II Water Tank Replacement: passo 12, imagem 3 %32
    • Lift the water tank up approximately 1 foot.
    • Place a base clamp around the exposed pipe and tighten it against the riser main.
  13. India Mark II Water Tank Replacement: passo 13, imagem 1 %32 India Mark II Water Tank Replacement: passo 13, imagem 2 %32
    • Secure the base clamp to the pump base with two bolt and nut sets installed on opposite sides of each other.
    • Hand tight will be sufficient for securing the base clamp.
    • Use the nuts and bolts removed from the water tank base or head section base.
  14. India Mark II Water Tank Replacement: passo 14, imagem 1 %32 India Mark II Water Tank Replacement: passo 14, imagem 2 %32
    • Turn the water tank counterclockwise until it comes free from the pipe.
    • Make sure to keep the tank level to prevent cross threading.
    • Lift the water tank up against the T-handle and secure the rod clamp to the pump rod.
  15. India Mark II Water Tank Replacement: passo 15, imagem 1 %32 India Mark II Water Tank Replacement: passo 15, imagem 2 %32
    • Remove the T-handle.
    • Remove the water tank and check for signs of blockage.
    • Store in a sanitary place to prevent contamination.
Conclusão
Phillip Takahashi
Membro desde: 08/22/11
87.349 Reputação
Autoria de 87 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,033
