Ir para o conteúdo principal
India Mark II Head Section Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. India Mark II Head Section Replacement, Cover Plate: passo 1, imagem 1 %32
    • Use a wrench to remove the bolt on the top of the cover plate.
    • When replacing the cover plate, this bolt only needs to be hand tight.
  2. India Mark II Head Section Replacement: passo 2, imagem 1 %32
    • Remove the top cover by pulling it straight off the pump.
    • Store the top cover in a sanitary place, preferably above ground, to prevent contamination.
  3. India Mark II Head Section Replacement, Head Section: passo 3, imagem 1 %32 India Mark II Head Section Replacement, Head Section: passo 3, imagem 2 %32 India Mark II Head Section Replacement, Head Section: passo 3, imagem 3 %32
    • Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
    • Place the spacer around the pump rod and under the chain attachment point.
    • Make sure the spacer is beveled side down, and flat side up.
    • Lift the pump lever until there is no tension in the chain and hold it in this position.
  4. India Mark II Head Section Replacement: passo 4, imagem 1 %32 India Mark II Head Section Replacement: passo 4, imagem 2 %32
    • Remove the bolt connecting the chain to the pump handle.
    • Remove the chain from the handle.
  5. India Mark II Head Section Replacement: passo 5, imagem 1 %32 India Mark II Head Section Replacement: passo 5, imagem 2 %32 India Mark II Head Section Replacement: passo 5, imagem 3 %32
    • There are 4 bolts securing the head section to the water tank, located at the corners of head section base.
    • Continue supporting the pump handle so the pump head doesn't fall off when all the bolts are removed.
    • Remove the 4 bolts on the base of the water tank.
  6. India Mark II Head Section Replacement: passo 6, imagem 1 %32
    • Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
Conclusão
Phillip Takahashi
Membro desde: 08/22/11
87.765 Reputação
Autoria de 87 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 34
Ao todo: 743
