Ir para o conteúdo principal
InFocus Screenplay 4805 Motherboard Replacement
O que você precisa
  1. InFocus Screenplay 4805 Motherboard Replacement, Top Panel: passo 1, imagem 1 %32 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: passo 1, imagem 2 %32 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: passo 1, imagem 3 %32
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
    Pergunte ao FixBot
    Comentar
  2. InFocus Screenplay 4805 Motherboard Replacement: passo 2, imagem 1 %32 InFocus Screenplay 4805 Motherboard Replacement: passo 2, imagem 2 %32
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
    Pergunte ao FixBot
    Comentar
  3. InFocus Screenplay 4805 Motherboard Replacement: passo 3, imagem 1 %32 InFocus Screenplay 4805 Motherboard Replacement: passo 3, imagem 2 %32 InFocus Screenplay 4805 Motherboard Replacement: passo 3, imagem 3 %32
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
    Pergunte ao FixBot
    Comentar
  4. InFocus Screenplay 4805 Motherboard Replacement: passo 4, imagem 1 %32
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
    Pergunte ao FixBot
    Comentar
  5. InFocus Screenplay 4805 Motherboard Replacement: passo 5, imagem 1 %32
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
    Pergunte ao FixBot
    Comentar
  6. InFocus Screenplay 4805 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: passo 6, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the (4) four 1.5 cm screws on each of the four corners of the motherboard cover.
    • Remove the white tab connected to the light bulb.
    Pergunte ao FixBot
    Comentar
  7. InFocus Screenplay 4805 Motherboard Replacement: passo 7, imagem 1 %32 InFocus Screenplay 4805 Motherboard Replacement: passo 7, imagem 2 %32 InFocus Screenplay 4805 Motherboard Replacement: passo 7, imagem 3 %32
    • Gently pull the white tab on the right side of the silver power housing by pinching each side of it.
    • Pinch the two black tabs on the inside of the cover to remove.
    • Gently pull on the long white tab to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 666
