Ir para o conteúdo principal
InFocus Screenplay 4805 Lens Replacement
O que você precisa
  1. InFocus Screenplay 4805 Lens Replacement, Top Panel: passo 1, imagem 1 %32 InFocus Screenplay 4805 Lens Replacement, Top Panel: passo 1, imagem 2 %32 InFocus Screenplay 4805 Lens Replacement, Top Panel: passo 1, imagem 3 %32
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
    Pergunte ao FixBot
    Comentar
  2. InFocus Screenplay 4805 Lens Replacement: passo 2, imagem 1 %32 InFocus Screenplay 4805 Lens Replacement: passo 2, imagem 2 %32
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
    Pergunte ao FixBot
    Comentar
  3. InFocus Screenplay 4805 Lens Replacement: passo 3, imagem 1 %32 InFocus Screenplay 4805 Lens Replacement: passo 3, imagem 2 %32 InFocus Screenplay 4805 Lens Replacement: passo 3, imagem 3 %32
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
    Pergunte ao FixBot
    Comentar
  4. InFocus Screenplay 4805 Lens Replacement: passo 4, imagem 1 %32
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
    Pergunte ao FixBot
    Comentar
  5. InFocus Screenplay 4805 Lens Replacement: passo 5, imagem 1 %32
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
    Pergunte ao FixBot
    Comentar
  6. InFocus Screenplay 4805 Lens Replacement, Lens: passo 6, imagem 1 %32 InFocus Screenplay 4805 Lens Replacement, Lens: passo 6, imagem 2 %32 InFocus Screenplay 4805 Lens Replacement, Lens: passo 6, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
    • Gently pull out the lens.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble the device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 900
