Ir para o conteúdo principal
InFocus LP540 Projector Speakers Replacement
O que você precisa
  1. InFocus LP540 Projector Speakers Replacement, Speakers: passo 1, imagem 1 %32 InFocus LP540 Projector Speakers Replacement, Speakers: passo 1, imagem 2 %32 InFocus LP540 Projector Speakers Replacement, Speakers: passo 1, imagem 3 %32
    • Flip the projector right-side up and turn it so the backports face you.
    • Remove the 7mm metallic hex screws using the screwdriver.
    • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
    Pergunte ao FixBot
    Comentar
  2. InFocus LP540 Projector Speakers Replacement: passo 2, imagem 1 %32 InFocus LP540 Projector Speakers Replacement: passo 2, imagem 2 %32
    • Remove the two 77mm screws that are located nearest to the back panel ports using a T10 Torx screwdriver.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver.
    • Flip the projector back over.
    • Cautiously lift the main lid to avoid ripping the electrical strips.
    Pergunte ao FixBot
    Comentar
  3. InFocus LP540 Projector Speakers Replacement: passo 3, imagem 1 %32 InFocus LP540 Projector Speakers Replacement: passo 3, imagem 2 %32
    • Unplug the speaker wire from the circuit board by squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    Pergunte ao FixBot
    Comentar
  4. InFocus LP540 Projector Speakers Replacement: passo 4, imagem 1 %32 InFocus LP540 Projector Speakers Replacement: passo 4, imagem 2 %32 InFocus LP540 Projector Speakers Replacement: passo 4, imagem 3 %32
    • Place the top shell of the projector down.
    • Remove the speaker wires from the white tabs.
    • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws.
    • Carefully lift the speakers to remove them.
    Pergunte ao FixBot
    Comentar
Conclusão
Reassembly: Close the speaker compartment and replace the light cover. Screw it back into place to secure all parts.
Equipe
Cal Poly, Team 13-17, Regan Winter 2014 Membro de Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 884
