Ir para o conteúdo principal
InFocus LP540 Projector Main Fans Replacement
O que você precisa
    1. InFocus LP540 Projector Main Fans Replacement, Main Board: passo 1, imagem 1 %32 InFocus LP540 Projector Main Fans Replacement, Main Board: passo 1, imagem 2 %32 InFocus LP540 Projector Main Fans Replacement, Main Board: passo 1, imagem 3 %32
      • Flip the projector right-side up and turn it so that the back ports are facing you.
      • Remove the 7 mm metallic screws using the flat-head screwdriver.
      • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
      Pergunte ao FixBot
      Comentar
    2. InFocus LP540 Projector Main Fans Replacement: passo 2, imagem 1 %32 InFocus LP540 Projector Main Fans Replacement: passo 2, imagem 2 %32
      • Flip the projector over.
      • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
      • Flip the projector back over.
      • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
      Pergunte ao FixBot
      Comentar
    3. InFocus LP540 Projector Main Fans Replacement: passo 3, imagem 1 %32 InFocus LP540 Projector Main Fans Replacement: passo 3, imagem 2 %32 InFocus LP540 Projector Main Fans Replacement: passo 3, imagem 3 %32
      • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      • Remove the top cover.
      Pergunte ao FixBot
      Comentar
    4. InFocus LP540 Projector Main Fans Replacement: passo 4, imagem 1 %32 InFocus LP540 Projector Main Fans Replacement: passo 4, imagem 2 %32
      • Hold down the release tabs to remove the cables from the white tabs.
      Pergunte ao FixBot
      Comentar
    5. InFocus LP540 Projector Main Fans Replacement: passo 5, imagem 1 %32 InFocus LP540 Projector Main Fans Replacement: passo 5, imagem 2 %32 InFocus LP540 Projector Main Fans Replacement: passo 5, imagem 3 %32
      • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
      • Pull up the five metal tabs located at the rear of the projector.
      • Do not pull up on the metal tabs too hard or too fast because they can break easily.
      Pergunte ao FixBot
      Comentar
    6. InFocus LP540 Projector Main Fans Replacement: passo 6, imagem 1 %32 InFocus LP540 Projector Main Fans Replacement: passo 6, imagem 2 %32 InFocus LP540 Projector Main Fans Replacement: passo 6, imagem 3 %32
      • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
      • Pull the ribbons out carefully and place them under the main board.
      • Carefully lift the entire main board up.
      Pergunte ao FixBot
      Comentar
    1. InFocus LP540 Projector Main Fans Replacement, Main Fans: passo 7, imagem 1 %32 InFocus LP540 Projector Main Fans Replacement, Main Fans: passo 7, imagem 2 %32
      • Once the main board has been removed, carefully lift the fans upward. Make sure no cables are tangled in the process.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 13-17, Regan Winter 2014 Membro de Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Membros
Autoria de 30 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 1,790
