Ir para o conteúdo principal
InFocus LP540 Projector Lens Replacement
O que você precisa
    1. InFocus LP540 Projector Lens Replacement, Main Board: passo 1, imagem 1 %32 InFocus LP540 Projector Lens Replacement, Main Board: passo 1, imagem 2 %32 InFocus LP540 Projector Lens Replacement, Main Board: passo 1, imagem 3 %32
      • Flip the projector right-side up and turn it so that the back ports are facing you.
      • Remove the 7 mm metallic screws using the flat-head screwdriver.
      • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
      Pergunte ao FixBot
      Comentar
    2. InFocus LP540 Projector Lens Replacement: passo 2, imagem 1 %32 InFocus LP540 Projector Lens Replacement: passo 2, imagem 2 %32
      • Flip the projector over.
      • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
      • Flip the projector back over.
      • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
      Pergunte ao FixBot
      Comentar
    3. InFocus LP540 Projector Lens Replacement: passo 3, imagem 1 %32 InFocus LP540 Projector Lens Replacement: passo 3, imagem 2 %32 InFocus LP540 Projector Lens Replacement: passo 3, imagem 3 %32
      • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      • Remove the top cover.
      Pergunte ao FixBot
      Comentar
    4. InFocus LP540 Projector Lens Replacement: passo 4, imagem 1 %32 InFocus LP540 Projector Lens Replacement: passo 4, imagem 2 %32
      • Hold down the release tabs to remove the cables from the white tabs.
      Pergunte ao FixBot
      Comentar
    5. InFocus LP540 Projector Lens Replacement: passo 5, imagem 1 %32 InFocus LP540 Projector Lens Replacement: passo 5, imagem 2 %32 InFocus LP540 Projector Lens Replacement: passo 5, imagem 3 %32
      • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
      • Pull up the five metal tabs located at the rear of the projector.
      • Do not pull up on the metal tabs too hard or too fast because they can break easily.
      Pergunte ao FixBot
      Comentar
    6. InFocus LP540 Projector Lens Replacement: passo 6, imagem 1 %32 InFocus LP540 Projector Lens Replacement: passo 6, imagem 2 %32 InFocus LP540 Projector Lens Replacement: passo 6, imagem 3 %32
      • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
      • Pull the ribbons out carefully and place them under the main board.
      • Carefully lift the entire main board up.
      Pergunte ao FixBot
      Comentar
    1. InFocus LP540 Projector Lens Replacement, Lens: passo 7, imagem 1 %32 InFocus LP540 Projector Lens Replacement, Lens: passo 7, imagem 2 %32
      • Remove the two 10 mm screws using the Philips 0 screwdriver head.
      Pergunte ao FixBot
      Comentar
    2. InFocus LP540 Projector Lens Replacement: passo 8, imagem 1 %32 InFocus LP540 Projector Lens Replacement: passo 8, imagem 2 %32
      • Carefully hold the lens from both ends and lift up simultaneously
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 13-17, Regan Winter 2014 Membro de Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 37
Ao todo: 3,029
