Ir para o conteúdo principal
InFocus IN35W Fan Replacement
O que você precisa
  1. InFocus IN35W Fan Replacement, Top Plate: passo 1, imagem 1 %32 InFocus IN35W Fan Replacement, Top Plate: passo 1, imagem 2 %32 InFocus IN35W Fan Replacement, Top Plate: passo 1, imagem 3 %32
    • Use the plastic opening tool to remove the front plastic casing surrounding the lens.
    • Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  2. InFocus IN35W Fan Replacement: passo 2, imagem 1 %32 InFocus IN35W Fan Replacement: passo 2, imagem 2 %32
    • Pull the top piece up.
    • The two gray ventilation grates will slip off the device.
    Pergunte ao FixBot
    Comentar
  3. InFocus IN35W Fan Replacement: passo 3, imagem 1 %32 InFocus IN35W Fan Replacement: passo 3, imagem 2 %32
    • Detach the white speaker wire that connects the motherboard to the top piece.
    • Remove the top cover from the device.
    Pergunte ao FixBot
    Comentar
  4. InFocus IN35W Fan Replacement, Motherboard: passo 4, imagem 1 %32 InFocus IN35W Fan Replacement, Motherboard: passo 4, imagem 2 %32
    • Detach all six of the cables and speaker wires from the white connectors on the motherboard.
    Pergunte ao FixBot
    Comentar
  5. InFocus IN35W Fan Replacement: passo 5, imagem 1 %32 InFocus IN35W Fan Replacement: passo 5, imagem 2 %32
    • Remove the six 4 mm Torx TR10 screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. InFocus IN35W Fan Replacement: passo 6, imagem 1 %32
    • Carefully grasp the outsides of the motherboard and pull it up to remove it from the device.
    Pergunte ao FixBot
    Comentar
  7. InFocus IN35W Fan Replacement, Fan: passo 7, imagem 1 %32 InFocus IN35W Fan Replacement, Fan: passo 7, imagem 2 %32
    • The fan is located on the side of the device.
    • Lift the fan up and out of the projector body.
    Pergunte ao FixBot
    Comentar
Conclusão
Grace Hubert
Membro desde: 10/18/21
608 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-2, Simcock Fall 2021 Membro de UMass Dartmouth, Team 1-2, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 30
Ao todo: 304
