Ir para o conteúdo principal
InFocus IN3104 Lamp Replacement
O que você precisa
  1. InFocus IN3104 Lamp Replacement, Top Cover: passo 1, imagem 1 %32 InFocus IN3104 Lamp Replacement, Top Cover: passo 1, imagem 2 %32 InFocus IN3104 Lamp Replacement, Top Cover: passo 1, imagem 3 %32
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
    Pergunte ao FixBot
    Comentar
  2. InFocus IN3104 Lamp Replacement: passo 2, imagem 1 %32 InFocus IN3104 Lamp Replacement: passo 2, imagem 2 %32 InFocus IN3104 Lamp Replacement: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  3. InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, imagem 1 %32 InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
    Pergunte ao FixBot
    Comentar
  4. InFocus IN3104 Lamp Replacement: passo 4, imagem 1 %32 InFocus IN3104 Lamp Replacement: passo 4, imagem 2 %32 InFocus IN3104 Lamp Replacement: passo 4, imagem 3 %32
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
    Pergunte ao FixBot
    Comentar
  5. InFocus IN3104 Lamp Replacement, Lamp: passo 5, imagem 1 %32 InFocus IN3104 Lamp Replacement, Lamp: passo 5, imagem 2 %32 InFocus IN3104 Lamp Replacement, Lamp: passo 5, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the four 6 mm screws.
    • You may need to use a flexible extender to help remove the screws easily.
    Pergunte ao FixBot
    Comentar
  6. InFocus IN3104 Lamp Replacement: passo 6, imagem 1 %32 InFocus IN3104 Lamp Replacement: passo 6, imagem 2 %32 InFocus IN3104 Lamp Replacement: passo 6, imagem 3 %32
    • Remove the lamp power cable situated beside the lamp by pulling it straight out.
    • Remove the lamp by pulling it straight out from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 60
Ao todo: 1,040
