Ir para o conteúdo principal
InFocus IN3104 Filter Replacement
O que você precisa
  1. InFocus IN3104 Filter Replacement, Top Cover: passo 1, imagem 1 %32 InFocus IN3104 Filter Replacement, Top Cover: passo 1, imagem 2 %32 InFocus IN3104 Filter Replacement, Top Cover: passo 1, imagem 3 %32
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
    Pergunte ao FixBot
    Comentar
  2. InFocus IN3104 Filter Replacement: passo 2, imagem 1 %32 InFocus IN3104 Filter Replacement: passo 2, imagem 2 %32 InFocus IN3104 Filter Replacement: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  3. InFocus IN3104 Filter Replacement, Filter: passo 3, imagem 1 %32 InFocus IN3104 Filter Replacement, Filter: passo 3, imagem 2 %32 InFocus IN3104 Filter Replacement, Filter: passo 3, imagem 3 %32
    • Use a Phillips # 1 screw driver to remove the 6 mm screw that secures the filter.
    • Once the screw is removed, remove the filter by pulling it straight out.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 33
Ao todo: 572
