Ir para o conteúdo principal
InFocus IN3104 Cooling Fan Replacement
O que você precisa
  1. InFocus IN3104 Cooling Fan Replacement, Top Cover: passo 1, imagem 1 %32 InFocus IN3104 Cooling Fan Replacement, Top Cover: passo 1, imagem 2 %32 InFocus IN3104 Cooling Fan Replacement, Top Cover: passo 1, imagem 3 %32
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
    Pergunte ao FixBot
    Comentar
  2. InFocus IN3104 Cooling Fan Replacement: passo 2, imagem 1 %32 InFocus IN3104 Cooling Fan Replacement: passo 2, imagem 2 %32 InFocus IN3104 Cooling Fan Replacement: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  3. InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, imagem 1 %32 InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
    Pergunte ao FixBot
    Comentar
  4. InFocus IN3104 Cooling Fan Replacement: passo 4, imagem 1 %32 InFocus IN3104 Cooling Fan Replacement: passo 4, imagem 2 %32 InFocus IN3104 Cooling Fan Replacement: passo 4, imagem 3 %32
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
    Pergunte ao FixBot
    Comentar
  5. InFocus IN3104 Cooling Fan Replacement, Cooling Fan: passo 5, imagem 1 %32 InFocus IN3104 Cooling Fan Replacement, Cooling Fan: passo 5, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the three 6 mm screws on the metal cover beside the lamp.
    • The screws are in a tight location, so you may need a thin screwdriver or an extension to remove them.
    Pergunte ao FixBot
    Comentar
  6. InFocus IN3104 Cooling Fan Replacement: passo 6, imagem 1 %32 InFocus IN3104 Cooling Fan Replacement: passo 6, imagem 2 %32 InFocus IN3104 Cooling Fan Replacement: passo 6, imagem 3 %32
    • Unplug the yellow, red, and black colored cable bundle from the motherboard.
    • Remove the cooling fan from the device by lifting it out.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 50
Ao todo: 851
