Ir para o conteúdo principal
InFocus IN3104 Color Wheel Replacement
O que você precisa
  1. InFocus IN3104 Color Wheel Replacement, Top Cover: passo 1, imagem 1 %32 InFocus IN3104 Color Wheel Replacement, Top Cover: passo 1, imagem 2 %32 InFocus IN3104 Color Wheel Replacement, Top Cover: passo 1, imagem 3 %32
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
    Pergunte ao FixBot
    Comentar
  2. InFocus IN3104 Color Wheel Replacement: passo 2, imagem 1 %32 InFocus IN3104 Color Wheel Replacement: passo 2, imagem 2 %32 InFocus IN3104 Color Wheel Replacement: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  3. InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, imagem 1 %32 InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
    Pergunte ao FixBot
    Comentar
  4. InFocus IN3104 Color Wheel Replacement: passo 4, imagem 1 %32 InFocus IN3104 Color Wheel Replacement: passo 4, imagem 2 %32 InFocus IN3104 Color Wheel Replacement: passo 4, imagem 3 %32
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
    Pergunte ao FixBot
    Comentar
  5. InFocus IN3104 Color Wheel Replacement, Color Wheel: passo 5, imagem 1 %32 InFocus IN3104 Color Wheel Replacement, Color Wheel: passo 5, imagem 2 %32 InFocus IN3104 Color Wheel Replacement, Color Wheel: passo 5, imagem 3 %32
    • Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO.
    Pergunte ao FixBot
    Comentar
  6. InFocus IN3104 Color Wheel Replacement: passo 6, imagem 1 %32 InFocus IN3104 Color Wheel Replacement: passo 6, imagem 2 %32
    • Carefully lift up the black paper cover. Do not completely remove it from the device.
    • Lift the paper cover up to reveal two 6mm screws.
    Pergunte ao FixBot
    Comentar
  7. InFocus IN3104 Color Wheel Replacement: passo 7, imagem 1 %32 InFocus IN3104 Color Wheel Replacement: passo 7, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 6mm screws.
    • Remove the color wheel from the device by lifting it out of the projector.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 52
Ao todo: 808
