Ir para o conteúdo principal
IdeaPad L340-15API Optical Drive Replacement
O que você precisa
    1. IdeaPad L340-15API Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32 IdeaPad L340-15API Optical Drive Replacement, Optical Drive: passo 1, imagem 2 %32
      • Before beginning the repair, make sure that the device is fully powered off.
      • Turn the laptop over so the bottom cover is facing up.
      • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
      Pergunte ao FixBot
      Comentar
    2. IdeaPad L340-15API Optical Drive Replacement: passo 2, imagem 1 %32 IdeaPad L340-15API Optical Drive Replacement: passo 2, imagem 2 %32
      • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
      • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
      Pergunte ao FixBot
      Comentar
    3. IdeaPad L340-15API Optical Drive Replacement: passo 3, imagem 1 %32 IdeaPad L340-15API Optical Drive Replacement: passo 3, imagem 2 %32
      • Place your thumb at the seam between the optical drive and the device.
      • Gently pull the component straight out from the device, taking care not to pull at an angle.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Ian
Membro desde: 10/15/25
347 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-5, Bowman Fall 2025 Membro de UMass Dartmouth, Team 2-5, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G5
4 Membros
Autoria de 36 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 27
Ao todo: 188
