Ir para o conteúdo principal
IQ America VD-8810L Motherboard Replacement
O que você precisa
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 IQ America VD-8810L Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 IQ America VD-8810L Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: passo 2, imagem 1 %32 IQ America VD-8810L Motherboard Replacement: passo 2, imagem 2 %32
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: passo 3, imagem 1 %32 IQ America VD-8810L Motherboard Replacement: passo 3, imagem 2 %32 IQ America VD-8810L Motherboard Replacement: passo 3, imagem 3 %32
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: passo 4, imagem 1 %32
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: passo 5, imagem 1 %32
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: passo 6, imagem 1 %32 IQ America VD-8810L Motherboard Replacement: passo 6, imagem 2 %32 IQ America VD-8810L Motherboard Replacement: passo 6, imagem 3 %32
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: passo 7, imagem 1 %32
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: passo 8, imagem 1 %32 IQ America VD-8810L Motherboard Replacement: passo 8, imagem 2 %32
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: passo 9, imagem 1 %32
    • Refer to this guide to desolder the speaker from the motherboard.
Conclusão
Jackey Lau
Membro desde: 10/17/17
301 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 238
