O que você precisa
Remove the brown plug.
The screw attaching the microwave is below
Remove the cross point screws from the outer case back
One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
The socket is on top right side of the microwave
Remove the plugs
Bend up the metal clips, and pull out the socket
Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
The glue goes all the way down the thread so remove as much as you can see.
Use leather gloves to unscrew in case the bulb breaks. It needs quite a lot of force so make sure you've got every bit of glue out.
When you re assemble the outer case make sure the tabs on the front go either side of the front.
4 outras pessoas executaram este guia.
