Ir para o conteúdo principal
ILVE Microwave Replacement Bulb Replacement
O que você precisa
    1. ILVE Microwave  Replacement Bulb Replacement, Remove the microwave from cabinate: passo 1, imagem 1 %32
      • Remove the brown plug.
      • The screw attaching the microwave is below
      Pergunte ao FixBot
      Comentar
    2. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: passo 2, imagem 1 %32 ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: passo 2, imagem 2 %32
      • Remove the cross point screws from the outer case back
      • One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
      • Take caution to ensure that no metal shards fall inside the microwave. You may want to tape over the holes or wipe the area off with a damp cloth or paper towel once finished.
      Pergunte ao FixBot
      Comentar
    3. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb socket: passo 3, imagem 1 %32
      • The socket is on top right side of the microwave
      • Remove the plugs
      • Bend up the metal clips, and pull out the socket
      Pergunte ao FixBot
      Comentar
    4. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: passo 4, imagem 1 %32 ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: passo 4, imagem 2 %32
      • Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
      • The glue goes all the way down the thread so remove as much as you can see.
      • Use leather gloves to unscrew in case the bulb breaks. It needs quite a lot of force so make sure you've got every bit of glue out.
      Pergunte ao FixBot
      Comentar
    5. ILVE Microwave  Replacement Bulb Replacement, Re assmeble: passo 5, imagem 1 %32
      • When you re assemble the outer case make sure the tabs on the front go either side of the front.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Martin Hampton
Membro desde: 02/13/16
1.350 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 54
Ao todo: 4,483
