Ir para o conteúdo principal
IBM ThinkPad X41 LCD Screen Replacement
O que você precisa
  1. IBM ThinkPad X41 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 IBM ThinkPad X41 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Open the laptop and turn to the side.
    • Using the spudger, remove the 6 black rectangular-shaped screw coverings (3 on each side)
    Pergunte ao FixBot
    Comentar
  2. IBM ThinkPad X41 LCD Screen Replacement: passo 2, imagem 1 %32
    • Using a Phillips Screw Driver, remove the (6) Phillips Head (Size PH001) 3.0 mm length screws (3 on each side) from the side of the LCD Screen Cover
    Pergunte ao FixBot
    Comentar
  3. IBM ThinkPad X41 LCD Screen Replacement: passo 3, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 3, imagem 2 %32
    • Using the spudger, remove the two round, black screw coverings on the lower, left, and right corners of the LCD screen bezel.
    Pergunte ao FixBot
    Comentar
  4. IBM ThinkPad X41 LCD Screen Replacement: passo 4, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 4, imagem 2 %32
    • Using a Phillips Screwdriver (Size PH001), remove the 3.0 mm screws from the lower, left and right corners of the LCD screen Bezel
    Pergunte ao FixBot
    Comentar
  5. IBM ThinkPad X41 LCD Screen Replacement: passo 5, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 5, imagem 2 %32
    • Using 2 Fingers, pull the bottom of the screen bezel towards you.
    • Pull the bottom of the screen bezel approximately 1 inch away from the LCD screen.
    • Next, pull screen bezel downward and away from the LCD screen.
    Pergunte ao FixBot
    Comentar
  6. IBM ThinkPad X41 LCD Screen Replacement: passo 6, imagem 1 %32
    • Using your index finger and thumb, gently lift and pull away laptop closure latch of the side of the screen assembly.
    Pergunte ao FixBot
    Comentar
  7. IBM ThinkPad X41 LCD Screen Replacement: passo 7, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 7, imagem 2 %32
    • Use a Phillips head screwdriver to remove the internal LCD screen support assembly above the F6 key.
    Pergunte ao FixBot
    Comentar
  8. IBM ThinkPad X41 LCD Screen Replacement: passo 8, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 8, imagem 2 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 8, imagem 3 %32
    • Close the laptop and turn so that the laptop's backside is facing you.
    • Using a thumb and index finger, gently lift the LCD screen back cover away from laptop.
    Pergunte ao FixBot
    Comentar
  9. IBM ThinkPad X41 LCD Screen Replacement: passo 9, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 9, imagem 2 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 9, imagem 3 %32
    • Using a spudger, remove the black, rectangular support tape.
    Pergunte ao FixBot
    Comentar
  10. IBM ThinkPad X41 LCD Screen Replacement: passo 10, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 10, imagem 2 %32
    • Carefully disconnect the orange cable from back of LCD screen.
    Pergunte ao FixBot
    Comentar
  11. IBM ThinkPad X41 LCD Screen Replacement: passo 11, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 11, imagem 2 %32
    • Using a Phillips Screwdriver (Size PH001), remove the screws from the LCD screen support arms.
    Pergunte ao FixBot
    Comentar
  12. IBM ThinkPad X41 LCD Screen Replacement: passo 12, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 12, imagem 2 %32
    • Unplug the orange LCD screen cable from the small circuit board near the laptop keyboard.
    Pergunte ao FixBot
    Comentar
  13. IBM ThinkPad X41 LCD Screen Replacement: passo 13, imagem 1 %32 IBM ThinkPad X41 LCD Screen Replacement: passo 13, imagem 2 %32
    • Using one hand, gently lift the LCD screen out of support arms.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Justin Macik
Membro desde: 09/12/16
228 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2016
CSUF-BRUCE-F16S2G4
4 Membros
Autoria de 8 guias
1Comentário do guia
nice little guide, short and too the point,
Vaughan Prendergast - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 38
Ao todo: 1,912
