Introdução
Removing the optical drive is extremely easy and will only a take a minute.
O que você precisa
Remove the single screw holding the optical drive on the underside of the laptop
Push the small slider to unlock position, a tab will automatically pop out.
Pull the tab to dislodge the optical drive, then carefully pull the drive out.
4 outras pessoas executaram este guia.
1Comentário do guia
What’s the interface for the optical drive? SATA? IDE?
