Ir para o conteúdo principal
IBM ThinkPad T41 Motherboard Replacement
O que você precisa
    1. IBM ThinkPad T41 Motherboard Replacement, Keyboard: passo 1, imagem 1 %32
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 2, imagem 1 %32
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad T41 Motherboard Replacement: passo 3, imagem 1 %32
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Pergunte ao FixBot
      Comentar
    4. IBM ThinkPad T41 Motherboard Replacement: passo 4, imagem 1 %32
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, Trackpad: passo 5, imagem 1 %32
      • Close the laptop and turn it over.
      • Remove the five plastic stickers covering the screws on the front edge of the case.
      • In order to reuse the stickers, remove them carefully.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 6, imagem 1 %32
      • Unscrew the five screws that were hidden by the stickers.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad T41 Motherboard Replacement: passo 7, imagem 1 %32
      • Turn the computer right side up and open the screen.
      • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
      • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
      Pergunte ao FixBot
      Comentar
    4. IBM ThinkPad T41 Motherboard Replacement: passo 8, imagem 1 %32
      • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, RAM: passo 9, imagem 1 %32
      • Push apart the retaining clips on the RAM.
      • Note: The RAM should pop up a little bit.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 10, imagem 1 %32
      • Lift out the RAM chip.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, Wireless Network Card: passo 11, imagem 1 %32
      • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 12, imagem 1 %32
      • Push apart the retaining clips.
      • Note: The card should pop up a little bit.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad T41 Motherboard Replacement: passo 13, imagem 1 %32
      • Pull the wireless network card out.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, CMOS Battery: passo 14, imagem 1 %32
      • Lift the yellow plastic-covered battery up.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 15, imagem 1 %32
      • Unplug the battery connector.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, Speakers: passo 16, imagem 1 %32
      • Lift the speakers out by starting with the left end and then unsnake the wires.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 17, imagem 1 %32
      • Unplug the wires from the motherboard.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, Expansion Slot: passo 18, imagem 1 %32
      • Remove the screw on the left hand side of the case, above the expansion slot.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 19, imagem 1 %32 IBM ThinkPad T41 Motherboard Replacement: passo 19, imagem 2 %32
      • Lift the black plastic border by lifting on either side.
      • Once the sides are up, pull the border towards you and away from the screen.
      • When lifting up, there are two pairs of plastic clips hooking into the fan grill. If you pull hard enough the border will come away, but it's better to push the clips with the spudger.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad T41 Motherboard Replacement: passo 20, imagem 1 %32
      • Pull the sheet metal cover away from slot.
      Pergunte ao FixBot
      Comentar
    4. IBM ThinkPad T41 Motherboard Replacement: passo 21, imagem 1 %32
      • Lift out the expansion slot by starting at the entrance hole and pulling upward.
      • Note: Try wiggling the slot from side to side until it comes out all the way.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, Modem: passo 22, imagem 1 %32
      • Remove the three screws holding down the modem in the upper left corner of the laptop.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 23, imagem 1 %32
      • Lift the modem up, unplugging it from the motherboard as you lift.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad T41 Motherboard Replacement: passo 24, imagem 1 %32 IBM ThinkPad T41 Motherboard Replacement: passo 24, imagem 2 %32
      • Pull out the wire that connects the modem to the screen.
      • Unplug the other cable that attaches the modem to the motherboard
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, Screen: passo 25, imagem 1 %32
      • Close the computer screen.
      • Remove the four screws on the back of the laptop, near the right and left hinges.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 26, imagem 1 %32
      • Open the laptop screen.
      • Remove the single screw that secures the left hinge to top of the computer.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad T41 Motherboard Replacement: passo 27, imagem 1 %32
      • Remove a single screw from the metal plate that secures the display cable.
      Pergunte ao FixBot
      Comentar
    4. IBM ThinkPad T41 Motherboard Replacement: passo 28, imagem 1 %32
      • Pull the metal plate away from the display cable.
      Pergunte ao FixBot
      Comentar
    5. IBM ThinkPad T41 Motherboard Replacement: passo 29, imagem 1 %32
      • Disconnect the display cable.
      Pergunte ao FixBot
      Comentar
    6. IBM ThinkPad T41 Motherboard Replacement: passo 30, imagem 1 %32
      • Carefully pull up the long antenna cables that were attached to the wireless network card.
      Pergunte ao FixBot
      Comentar
    7. IBM ThinkPad T41 Motherboard Replacement: passo 31, imagem 1 %32
      • Lift out the screen.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, Fan: passo 32, imagem 1 %32
      • Unsnake the black cable from the black plastic frame.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 33, imagem 1 %32
      • Remove the sheet metal piece, which was underneath the modem.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad T41 Motherboard Replacement: passo 34, imagem 1 %32
      • Remove the rubber microphone cover in the upper left hand corner by lifting up the gray metal frame.
      Pergunte ao FixBot
      Comentar
    4. IBM ThinkPad T41 Motherboard Replacement: passo 35, imagem 1 %32
      • Lift away the gray metal frame.
      Pergunte ao FixBot
      Comentar
    5. IBM ThinkPad T41 Motherboard Replacement: passo 36, imagem 1 %32
      • Remove three screws near the edge of the computer, holding the optical bay and HDD covers.
      • Remove three other screws on the other side of the covers.
      • You should have six screws in total, three of one size and three of another size.
      Pergunte ao FixBot
      Comentar
    6. IBM ThinkPad T41 Motherboard Replacement: passo 37, imagem 1 %32
      • Lift out the optical bay and HDD covers.
      Pergunte ao FixBot
      Comentar
    7. IBM ThinkPad T41 Motherboard Replacement: passo 38, imagem 1 %32
      • Lift out the black plastic frame.
      Pergunte ao FixBot
      Comentar
    8. IBM ThinkPad T41 Motherboard Replacement: passo 39, imagem 1 %32
      • Unplug the fan from the motherboard.
      Pergunte ao FixBot
      Comentar
    9. IBM ThinkPad T41 Motherboard Replacement: passo 40, imagem 1 %32
      • Remove the three screws on the fan.
      Pergunte ao FixBot
      Comentar
    10. IBM ThinkPad T41 Motherboard Replacement: passo 41, imagem 1 %32
      • Lift the fan out.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, CPU: passo 42, imagem 1 %32
      • Turn the CPU retaining screw 90 degrees counterclockwise.
      • Carefully pull the CPU out of its socket.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad T41 Motherboard Replacement, Motherboard: passo 43, imagem 1 %32
      • Remove the two screws in the upper right corner that secure the gray metal frame.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad T41 Motherboard Replacement: passo 44, imagem 1 %32
      • Unplug the small ribbon cable attached to the motherboard.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad T41 Motherboard Replacement: passo 45, imagem 1 %32
      • Remove the single screw located next to the USB slots.
      Pergunte ao FixBot
      Comentar
    4. IBM ThinkPad T41 Motherboard Replacement: passo 46, imagem 1 %32
      • Rotate the device so that the front faces you.
      • Lift the entire motherboard assembly out of the case.
      Pergunte ao FixBot
      Comentar
    5. IBM ThinkPad T41 Motherboard Replacement: passo 47, imagem 1 %32
      • Disconnect the power connector from the motherboard.
      Pergunte ao FixBot
      Comentar
    6. IBM ThinkPad T41 Motherboard Replacement: passo 48, imagem 1 %32
      • Using a nut driver or a pair of thin nose pliers, remove the two stand off screws next to the pink parallel port on the back of the computer.
      Pergunte ao FixBot
      Comentar
    7. IBM ThinkPad T41 Motherboard Replacement: passo 49, imagem 1 %32
      • Lift up the outer end of the grey metal frame.
      • Carefully rotate the frame clockwise to release it from the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
20 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 7-8, Maness Spring 2010 Membro de Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Membros
Autoria de 78 guias
6Comentários do guia
Hello,
Thanks for this !
When assembling again, I noticed that at the contact between the micro-processor and the cooler the thermal paste there was a very small amount of thermal paste.
I had none to add, therefore I reassembled as is.
After starting the machine again I note that the cooling fan never stops.
I suggest that at reassembling should thermal paste added.
Philippe - Responder Compartilhar
ibm thinkpad t42 laptop driver are not download please sir my laptop motherboard information send in my email id . how can download driver download for ibm laptop
Himanshu Kumar - Responder Compartilhar
Excellent tutorial. Thank you.
genese_cranford - Responder Compartilhar
thanks alot!
Geburtswehe - Responder Compartilhar
It’s tempting to try, but I’d feel much braver with a reassembly tutorial!
Christine Segatti - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 68
Ao todo: 51,288
