Ir para o conteúdo principal
IBM ThinkPad T30 Hard Drive Replacement
O que você precisa
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
    Pergunte ao FixBot
    Comentar
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. IBM ThinkPad T30 Hard Drive Replacement: passo 3, imagem 1 %32 IBM ThinkPad T30 Hard Drive Replacement: passo 3, imagem 2 %32 IBM ThinkPad T30 Hard Drive Replacement: passo 3, imagem 3 %32
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
    Pergunte ao FixBot
    Comentar
  4. IBM ThinkPad T30 Hard Drive Replacement: passo 4, imagem 1 %32 IBM ThinkPad T30 Hard Drive Replacement: passo 4, imagem 2 %32
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
    Pergunte ao FixBot
    Comentar
  5. IBM ThinkPad T30 Hard Drive Replacement: passo 5, imagem 1 %32 IBM ThinkPad T30 Hard Drive Replacement: passo 5, imagem 2 %32
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
11 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 3-20, Amido Fall 2012 Membro de Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Membros
Autoria de 17 guias
1Comentário do guia
good description and photos..thanks :]
David - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 26
Últimos 30 dias: 96
Ao todo: 20,704
