Ir para o conteúdo principal
IBM ThinkPad R40 Keyboard Keys Replacement
O que você precisa
    1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: passo 1, imagem 1 %32
      • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: passo 2, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: passo 3, imagem 1 %32
      • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
      Pergunte ao FixBot
      Comentar
    4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: passo 4, imagem 1 %32
      • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
      Pergunte ao FixBot
      Comentar
    5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: passo 5, imagem 1 %32
      • After lining the key up, the black and white pieces will line up.
      Pergunte ao FixBot
      Comentar
    6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: passo 6, imagem 1 %32
      • Step 6: The key should not be firmly locked into place and functioning normally.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Erin
Membro desde: 09/08/11
231 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 46
Ao todo: 5,306
