Ir para o conteúdo principal
IBM ThinkPad 560z Screen Replacement
O que você precisa
    1. IBM ThinkPad 560z Screen Replacement, Battery Removal: passo 1, imagem 1 %32
      • Slide the battery release latch to the right.
      • Pull out the battery out towards the front of the device.
      Pergunte ao FixBot
      Comentar
    1. IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: passo 2, imagem 1 %32 IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: passo 2, imagem 2 %32
      • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
      Pergunte ao FixBot
      Comentar
    2. IBM ThinkPad 560z Screen Replacement, Screen Bezel Removal: passo 3, imagem 1 %32
      • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
      Pergunte ao FixBot
      Comentar
    3. IBM ThinkPad 560z Screen Replacement, LCD Removal Preperation: passo 4, imagem 1 %32
      • Remove the four Phillips head screws.
      Pergunte ao FixBot
      Comentar
    4. IBM ThinkPad 560z Screen Replacement, Ribbon Cable Disconnection: passo 5, imagem 1 %32
      • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
      Pergunte ao FixBot
      Comentar
    5. IBM ThinkPad 560z Screen Replacement, LCD Removal: passo 6, imagem 1 %32 IBM ThinkPad 560z Screen Replacement, LCD Removal: passo 6, imagem 2 %32
      • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
      • The connector is very fragile, so be careful.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 26-27, Regan Spring 2010 Membro de Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Membros
Autoria de 54 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 5,429
