Ir para o conteúdo principal
Hytera TC-580 Microphone Replacement
O que você precisa
  1. Hytera TC-580 Microphone Replacement, Battery: passo 1, imagem 1 %32 Hytera TC-580 Microphone Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two 10mm Phillips #0 from the belt clip.
    Pergunte ao FixBot
    Comentar
  2. Hytera TC-580 Microphone Replacement: passo 2, imagem 1 %32 Hytera TC-580 Microphone Replacement: passo 2, imagem 2 %32
    • Push in the release button and pull up on the battery to remove.
    Pergunte ao FixBot
    Comentar
  3. Hytera TC-580 Microphone Replacement, Antenna: passo 3, imagem 1 %32
    • Twist antenna counter-clockwise and set damaged antenna aside.
    Pergunte ao FixBot
    Comentar
  4. Hytera TC-580 Microphone Replacement, Keypad: passo 4, imagem 1 %32
    • Remove the volume knob by firmly lifting up on both sides of it.
    Pergunte ao FixBot
    Comentar
  5. Hytera TC-580 Microphone Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the orange o-ring around volume knob using tweezers.
    Pergunte ao FixBot
    Comentar
  6. Hytera TC-580 Microphone Replacement: passo 6, imagem 1 %32
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
    Pergunte ao FixBot
    Comentar
  7. Hytera TC-580 Microphone Replacement: passo 7, imagem 1 %32
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
    Pergunte ao FixBot
    Comentar
  8. Hytera TC-580 Microphone Replacement: passo 8, imagem 1 %32 Hytera TC-580 Microphone Replacement: passo 8, imagem 2 %32
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
    Pergunte ao FixBot
    Comentar
  9. Hytera TC-580 Microphone Replacement: passo 9, imagem 1 %32
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
    Pergunte ao FixBot
    Comentar
  10. Hytera TC-580 Microphone Replacement: passo 10, imagem 1 %32
    • Peel off the keypad by hand.
    Pergunte ao FixBot
    Comentar
  11. Hytera TC-580 Microphone Replacement, Speaker: passo 11, imagem 1 %32 Hytera TC-580 Microphone Replacement, Speaker: passo 11, imagem 2 %32 Hytera TC-580 Microphone Replacement, Speaker: passo 11, imagem 3 %32
    • Remove eleven 4mm Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  12. Hytera TC-580 Microphone Replacement: passo 12, imagem 1 %32
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
    Pergunte ao FixBot
    Comentar
  13. Hytera TC-580 Microphone Replacement, Microphone: passo 13, imagem 1 %32
    • If not already done, remove the circuit board completely from the case.
    Pergunte ao FixBot
    Comentar
  14. Hytera TC-580 Microphone Replacement: passo 14, imagem 1 %32
    • Desolder the two microphone solder joints.
    Pergunte ao FixBot
    Comentar
  15. Hytera TC-580 Microphone Replacement: passo 15, imagem 1 %32
    • The microphone should fall out after all the solder has been removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Stuart
Membro desde: 02/14/18
485 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S3-G4, Nance Spring 2018 Membro de USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 1,183
