Ir para o conteúdo principal
Hytera TC-580 Keypad Replacement
O que você precisa
  1. Hytera TC-580 Keypad Replacement, Battery: passo 1, imagem 1 %32 Hytera TC-580 Keypad Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two 10mm Phillips #0 from the belt clip.
    Pergunte ao FixBot
    Comentar
  2. Hytera TC-580 Keypad Replacement: passo 2, imagem 1 %32 Hytera TC-580 Keypad Replacement: passo 2, imagem 2 %32
    • Push in the release button and pull up on the battery to remove.
    Pergunte ao FixBot
    Comentar
  3. Hytera TC-580 Keypad Replacement, Antenna: passo 3, imagem 1 %32
    • Twist antenna counter-clockwise and set damaged antenna aside.
    Pergunte ao FixBot
    Comentar
  4. Hytera TC-580 Keypad Replacement, Keypad: passo 4, imagem 1 %32
    • Remove the volume knob by firmly lifting up on both sides of it.
    Pergunte ao FixBot
    Comentar
  5. Hytera TC-580 Keypad Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the orange o-ring around volume knob using tweezers.
    Pergunte ao FixBot
    Comentar
  6. Hytera TC-580 Keypad Replacement: passo 6, imagem 1 %32
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
    Pergunte ao FixBot
    Comentar
  7. Hytera TC-580 Keypad Replacement: passo 7, imagem 1 %32
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
    Pergunte ao FixBot
    Comentar
  8. Hytera TC-580 Keypad Replacement: passo 8, imagem 1 %32 Hytera TC-580 Keypad Replacement: passo 8, imagem 2 %32
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
    Pergunte ao FixBot
    Comentar
  9. Hytera TC-580 Keypad Replacement: passo 9, imagem 1 %32
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
    Pergunte ao FixBot
    Comentar
  10. Hytera TC-580 Keypad Replacement: passo 10, imagem 1 %32
    • Peel off the keypad by hand.
    Pergunte ao FixBot
    Comentar
Conclusão
Stuart
Membro desde: 02/14/18
485 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S3-G4, Nance Spring 2018 Membro de USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 705
