Ir para o conteúdo principal
HyperX QuadCast S Pop Filter Replacement
  1. HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: passo 1, imagem 1 %32 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: passo 1, imagem 2 %32 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: passo 1, imagem 3 %32
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
    Pergunte ao FixBot
    Comentar
  2. HyperX QuadCast S Pop Filter Replacement: passo 2, imagem 1 %32 HyperX QuadCast S Pop Filter Replacement: passo 2, imagem 2 %32 HyperX QuadCast S Pop Filter Replacement: passo 2, imagem 3 %32
    • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
    • Be careful not to damage the cable as you remove the top.
    • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
    Pergunte ao FixBot
    Comentar
  3. HyperX QuadCast S Pop Filter Replacement: passo 3, imagem 1 %32 HyperX QuadCast S Pop Filter Replacement: passo 3, imagem 2 %32 HyperX QuadCast S Pop Filter Replacement: passo 3, imagem 3 %32
    • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
    • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
    Pergunte ao FixBot
    Comentar
  4. HyperX QuadCast S Pop Filter Replacement, Pop Filter: passo 4, imagem 1 %32
    • Once the Tap-To-Mute sensor has been removed, you will now have access to the pop filter.
    • The pop filter is just the grey foam surrounding the inside of the microphone.
    Pergunte ao FixBot
    Comentar
  5. HyperX QuadCast S Pop Filter Replacement: passo 5, imagem 1 %32
    • The pop filter will be in a fixed position being glued to the wire. Remove glue residue before continuing to remove the pop filter.
    • When you replace the pop filter, remember that you will need to glue it back into place as before.
    Pergunte ao FixBot
    Comentar
  6. HyperX QuadCast S Pop Filter Replacement: passo 6, imagem 1 %32 HyperX QuadCast S Pop Filter Replacement: passo 6, imagem 2 %32
    • Reach into the microphone and remove the pop filter.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nathan Arruda
Membro desde: 10/25/22
765 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G1
5 Membros
Autoria de 9 guias
3Comentários do guia
"Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion."
This part is keyed. It literally cannot be pulled in any rotational motion...
Kyle Villalovos - Responder Compartilhar
Is there a place where you recomend i can get a replacement peice of foam for the pop filter. I cant find one anywhere online.
Liam Henesy - Responder Compartilhar
did you happen to find anything?
Kamen C-Swartz - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 104
Ao todo: 4,408
