Ir para o conteúdo principal
HyperX Pulsefire Haste Battery Replacement
O que você precisa
    1. HyperX Pulsefire Haste Battery Replacement, Battery: passo 1, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement, Battery: passo 1, imagem 2 %32
      • Power off the mouse using the switch located underneath and rest on the underside.
      Pergunte ao FixBot
      Comentar
    2. HyperX Pulsefire Haste Battery Replacement: passo 2, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 2, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 2, imagem 3 %32
      • Using the plastic spudger, remove the white mouse sticker grips on both sides of lower portion of the bottom mouse to reveal the screw holes underneath.
      Pergunte ao FixBot
      Comentar
    3. HyperX Pulsefire Haste Battery Replacement: passo 3, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 3, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 3, imagem 3 %32
      • Remove both of the screws on the bottom of the mouse using a TR6 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    4. HyperX Pulsefire Haste Battery Replacement: passo 4, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 4, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 4, imagem 3 %32
      • Use the plastic spudger to separate the mouse covering from the base on both sides of the mouse.
      • It is helpful to place the spudger in the front crevices underneath the mouse buttons and move in upward and downward motions until it loosens.
      Pergunte ao FixBot
      Comentar
    5. HyperX Pulsefire Haste Battery Replacement: passo 5, imagem 1 %32
      • Remove the three screws located on the battery casing at the top, left, and right sides using a TR6 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    6. HyperX Pulsefire Haste Battery Replacement: passo 6, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 6, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 6, imagem 3 %32
      • Use the plastic spudger to gently lift the battery cover with the battery inside, ensuring the wiring is still connected, setting it nearby.
      Pergunte ao FixBot
      Comentar
    7. HyperX Pulsefire Haste Battery Replacement: passo 7, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 7, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 7, imagem 3 %32
      • Use the tweezers to grab the white connector and remove the battery wiring from the mouse base.
      Pergunte ao FixBot
      Comentar
    8. HyperX Pulsefire Haste Battery Replacement: passo 8, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 8, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 8, imagem 3 %32
      • Place the new battery with the label facing upwards into the casing.
      • Ensure you set the old battery aside to be able to be properly disposed of, either by taking it to a recycling center or returning it to the retailer. Do not throw the battery in the trash.
      Pergunte ao FixBot
      Comentar
    9. HyperX Pulsefire Haste Battery Replacement: passo 9, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 9, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 9, imagem 3 %32
      • Using the tweezers, gently connect the wire back to its location, while ensuring the three pins are back in their original pinholes.
      Pergunte ao FixBot
      Comentar
    10. HyperX Pulsefire Haste Battery Replacement: passo 10, imagem 1 %32
      • Using the TR6 Torx screwdriver, screw back all three of the screws originally taken off of the battery casing.
      Pergunte ao FixBot
      Comentar
    11. HyperX Pulsefire Haste Battery Replacement: passo 11, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 11, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 11, imagem 3 %32
      • Place the mouse covering back on, ensuring the component is properly aligned with the screw holes underneath.
      Pergunte ao FixBot
      Comentar
    12. HyperX Pulsefire Haste Battery Replacement: passo 12, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 12, imagem 2 %32
      • Screw both of the outer screws back on the lower bottom of the mouse using a TR6 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    13. HyperX Pulsefire Haste Battery Replacement: passo 13, imagem 1 %32 HyperX Pulsefire Haste Battery Replacement: passo 13, imagem 2 %32 HyperX Pulsefire Haste Battery Replacement: passo 13, imagem 3 %32
      • Place the mouse sticker grips that you previously took off back on to cover the screw holes.
      Pergunte ao FixBot
      Comentar
Conclusão
Congratulations! You have successfully completed replacing the battery inside of your wireless mouse! You can now use your knowledge you have gained from this replacement in future similar scenarios and continue on doing your part in reducing the amount of e-waste on our planet.
luna
Membro desde: 09/19/24
217 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 34
Últimos 30 dias: 131
Ao todo: 2,830
