Ir para o conteúdo principal
HyperX Cloud Alpha Hinges Replacement
O que você precisa
  1. HyperX Cloud Alpha Hinges Replacement, Hinges: passo 1, imagem 1 %32 HyperX Cloud Alpha Hinges Replacement, Hinges: passo 1, imagem 2 %32
    • Remove the two screws attaching the hinge to the back side of the speakers with a Philips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. HyperX Cloud Alpha Hinges Replacement: passo 2, imagem 1 %32
    • Remove the broken hinge from the speaker.
    Pergunte ao FixBot
    Comentar
  3. HyperX Cloud Alpha Hinges Replacement: passo 3, imagem 1 %32 HyperX Cloud Alpha Hinges Replacement: passo 3, imagem 2 %32
    • Remove the two screws from the clips attaching the hinges to the headband. This will free the hinge.
    • To replace the other hinge, repeat Steps 1-3 on the other side.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Shania
Membro desde: 10/25/22
137 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 5-4, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G4
5 Membros
Autoria de 8 guias
2Comentários do guia
you went and posted the screwdriver in the part we need but you didnt include the most important thing the replacement hinge to replace the broken hinge...
Branden Tomaino - Responder Compartilhar
I need to change them on my headset. How do i deal with the wire that goes through the plastic part ? Is there some soldering needed ?
Adelino Antunes - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 33
Últimos 30 dias: 174
Ao todo: 5,509
