Introdução
The adjustment slider helps the headphones change their size to either tight or loose around the head depending on your preference. If your headband is not adjusting properly or is uncomfortable, try referring back to the HyperX Cloud Alpha Troubleshooting page. If our troubleshooting page is of no use, use our replacement guide to replace the slider.
O que você precisa
Remove the two Phillips #1 screws from the clips located on the headband.
Repeat on the other clip. (If you did the right side first, then do the left and vice-versa.)
