Ir para o conteúdo principal
HyperX Alloy Origins Key Switch Replacement
O que você precisa
  1. HyperX Alloy Origins Key Switch Replacement, Toggle Indicator Tab: passo 1, imagem 1 %32
    • Locate the toggle indicator tab on the top right corner of the keyboard.
    Pergunte ao FixBot
    Comentar
  2. HyperX Alloy Origins Key Switch Replacement: passo 2, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement: passo 2, imagem 2 %32
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
    Pergunte ao FixBot
    Comentar
  3. HyperX Alloy Origins Key Switch Replacement, Backplate: passo 3, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement, Backplate: passo 3, imagem 2 %32
    • Flip the keyboard over so that the backplate is facing you.
    Pergunte ao FixBot
    Comentar
  4. HyperX Alloy Origins Key Switch Replacement: passo 4, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement: passo 4, imagem 2 %32 HyperX Alloy Origins Key Switch Replacement: passo 4, imagem 3 %32
    • Remove the rubber feet on the four corners of the backplate.
    • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
    Pergunte ao FixBot
    Comentar
  5. HyperX Alloy Origins Key Switch Replacement: passo 5, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement: passo 5, imagem 2 %32 HyperX Alloy Origins Key Switch Replacement: passo 5, imagem 3 %32
    • Remove the specified keycaps as depicted in the image.
    Pergunte ao FixBot
    Comentar
  6. HyperX Alloy Origins Key Switch Replacement: passo 6, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement: passo 6, imagem 2 %32 HyperX Alloy Origins Key Switch Replacement: passo 6, imagem 3 %32
    • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
    Pergunte ao FixBot
    Comentar
  7. HyperX Alloy Origins Key Switch Replacement: passo 7, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement: passo 7, imagem 2 %32 HyperX Alloy Origins Key Switch Replacement: passo 7, imagem 3 %32
    • Separate the backplate from the keyboard using your hands.
    Pergunte ao FixBot
    Comentar
  8. HyperX Alloy Origins Key Switch Replacement, Key Switch: passo 8, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement, Key Switch: passo 8, imagem 2 %32 HyperX Alloy Origins Key Switch Replacement, Key Switch: passo 8, imagem 3 %32
    • Identify the key switch to be replaced.
    • Remove its keycap by carefully prying it off of the keyboard with your fingers.
    Pergunte ao FixBot
    Comentar
  9. HyperX Alloy Origins Key Switch Replacement: passo 9, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement: passo 9, imagem 2 %32
    • Flip the keyboard over to face the PCB.
    • Identify the corresponding switch to be removed.
    Pergunte ao FixBot
    Comentar
  10. HyperX Alloy Origins Key Switch Replacement: passo 10, imagem 1 %32
    • Plug in and turn on your soldering iron.
    • Do not touch the metal end of the soldering iron while it is powered on. Allow the soldering iron to cool before stowing it away.
    Pergunte ao FixBot
    Comentar
  11. HyperX Alloy Origins Key Switch Replacement: passo 11, imagem 1 %32 HyperX Alloy Origins Key Switch Replacement: passo 11, imagem 2 %32 HyperX Alloy Origins Key Switch Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • Melt the solder surrounding the four pins of the switch's LED, and the two lower pins of the switch body.
    • To remove the melted solder, use a desoldering iron, a desoldering pump, or desoldering braid.
    • The exposed switch pins are susceptible to damage from the soldering iron. Avoid applying heavy pressure to mitigate pin bending.
    Pergunte ao FixBot
    Comentar
  12. HyperX Alloy Origins Key Switch Replacement: passo 12, imagem 1 %32
    • Using a spudger or another metallic instrument, firmly press down upon the exposed plastic of the switch. This will separate the switch from the rest of the keyboard.
    • If the switch's pins will not separate from the keyboard's PCB, continue applying the soldering iron to the pins to melt any residual solder.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Note that when reattaching the switch back to the keyboard PCB, the switch needs to be held in place behind the keyboard while soldering.
7 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Membros
Autoria de 15 guias
7Comentários do guia
Hi, I needed to replace the stabilizers for my spacebar and was able to repaire it successfully by removing the spacebar switch and using the stabilizers from the + key on the keypad which I dont care about. But now when I plug in the keyboard, there's no power at all and no input. If I didn't solder the spacebar switch back on properly, could this cause the whole keyboard to stop working? Also, I decided not to put the + switch back on since I wouldnt be using it anyway.
André Léger - Responder Compartilhar
I need to replace some switches on the same keyboard and I don't know yet. where to buy it or what is the switch model or manufacturer, could you help me with that information?
Gerardo - Responder Compartilhar
Holaaa ando buscando un diagrama del circuito del teclado, ya que al cambiar un led una parte del teclado solo ilumina color rojo y los demas iluman en rgb :C
Francisco Alcalá - Responder Compartilhar
The W key isn’t working on my sons HyperX Alloy Origins Keyboard… he’s cleaned underneath all keys for any debris and tried pressing the escape and function keys at the same time to try and reset plus tried plugging the usb into another port but W key still doesn’t work. Any other suggestions? Can you buy a replacement W key for this keyboard?
A_J - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 93
Últimos 30 dias: 462
Ao todo: 35,288
