Ir para o conteúdo principal
Huawei Watch Jewel Battery Replacement
O que você precisa
    1. Huawei Watch Jewel Battery Replacement, Strap: passo 1, imagem 1 %32 Huawei Watch Jewel Battery Replacement, Strap: passo 1, imagem 2 %32
      • Begin by laying the watch on a flat, smooth surface.
      • This will prevent the watch screen from suffering damage.
      • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
      Pergunte ao FixBot
      Comentar
    2. Huawei Watch Jewel Battery Replacement: passo 2, imagem 1 %32 Huawei Watch Jewel Battery Replacement: passo 2, imagem 2 %32
      • Locate the two springs on the back of your watch.
      • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
      Pergunte ao FixBot
      Comentar
    3. Huawei Watch Jewel Battery Replacement: passo 3, imagem 1 %32 Huawei Watch Jewel Battery Replacement: passo 3, imagem 2 %32 Huawei Watch Jewel Battery Replacement: passo 3, imagem 3 %32
      • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
      Pergunte ao FixBot
      Comentar
    4. Huawei Watch Jewel Battery Replacement: passo 4, imagem 1 %32
      • Carefully pull the strap away from the watch.
      Pergunte ao FixBot
      Comentar
    5. Huawei Watch Jewel Battery Replacement: passo 5, imagem 1 %32 Huawei Watch Jewel Battery Replacement: passo 5, imagem 2 %32
      • Repeat step 3, this time using the other strap.
      Pergunte ao FixBot
      Comentar
    1. Huawei Watch Jewel Battery Replacement, Motherboard: passo 6, imagem 1 %32
      • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
      Pergunte ao FixBot
      Comentar
    2. Huawei Watch Jewel Battery Replacement: passo 7, imagem 1 %32 Huawei Watch Jewel Battery Replacement: passo 7, imagem 2 %32
      • Use the Metal Spudger to pry open the back of your watch.
      • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
      Pergunte ao FixBot
      Comentar
    3. Huawei Watch Jewel Battery Replacement: passo 8, imagem 1 %32
      • Remove the back case.
      Pergunte ao FixBot
      Comentar
    4. Huawei Watch Jewel Battery Replacement: passo 9, imagem 1 %32 Huawei Watch Jewel Battery Replacement: passo 9, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
      • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
      Pergunte ao FixBot
      Comentar
    5. Huawei Watch Jewel Battery Replacement: passo 10, imagem 1 %32
      • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
      • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
      Pergunte ao FixBot
      Comentar
    6. Huawei Watch Jewel Battery Replacement: passo 11, imagem 1 %32
      Spudger
      $2.99
      • Use the Metal Spudger to lift the mother board from the watch.
      • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
      Pergunte ao FixBot
      Comentar
    7. Huawei Watch Jewel Battery Replacement: passo 12, imagem 1 %32
      • Remove the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Huawei Watch Jewel Battery Replacement, Battery: passo 13, imagem 1 %32
      iFixit Opening Picks (Set of 6)
      $4.95
      • Use the spudger or opening pick to carefully lift the battery from the watch.
      • Ensure that the polarity (+/- signs) of the new battery match that of the old battery when inserting new battery into device.
      • Avoid using a metal spudger as it may cause damage to the battery or device. Use an opening pick when possible.
      Pergunte ao FixBot
      Comentar
Conclusão
21 outras pessoas executaram este guia.
ngan tran
Membro desde: 02/15/17
526 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-3, Passmore Spring 2017 Membro de USF Tampa, Team 5-3, Passmore Spring 2017
USFT-PASSMORE-S17S5G3
4 Membros
Autoria de 9 guias
8Comentários do guia
Any idea where one can purchase the actual battery? I can’t find one anywhere.
Chris Wellings - Responder Compartilhar
@Chris wellings: i was able to find one on ebay. Arrived quite quickly. And you definitely need a T2(not 3) screwdriver to open up the watch.
edgar.dumea - Responder Compartilhar
Also found one on eBay. I was replacing the battery on the standard Huawei Watch (W1) and this guide was really helpful.
Alex Swanson - Responder Compartilhar
thanks for this great guide, it’s very clear. My W1’s battery is still OK, but I’m anticipating needing to change it sometime and your guide removes the fear!
Paul M - Responder Compartilhar
T2 or T3 Torx ???
Carlos - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 53
Ao todo: 24,423
