Ir para o conteúdo principal
Huawei Union Screen Replacement
O que você precisa
  1. Huawei Union Screen Replacement, Battery: passo 1, imagem 1 %32 Huawei Union Screen Replacement, Battery: passo 1, imagem 2 %32
    • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
    Pergunte ao FixBot
    Comentar
  2. Huawei Union Screen Replacement: passo 2, imagem 1 %32 Huawei Union Screen Replacement: passo 2, imagem 2 %32
    • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
    Pergunte ao FixBot
    Comentar
  3. Huawei Union Screen Replacement, Camera Lens Panel: passo 3, imagem 1 %32
    • Remove the thirteen 3mm Phillips #00 screws from the back panel.
    Pergunte ao FixBot
    Comentar
  4. Huawei Union Screen Replacement: passo 4, imagem 1 %32
    • Use the flat end of a spudger to pry off the back panel.
    Pergunte ao FixBot
    Comentar
  5. Huawei Union Screen Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove a single 3mm Phillips #00 screw from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Huawei Union Screen Replacement: passo 6, imagem 1 %32 Huawei Union Screen Replacement: passo 6, imagem 2 %32
    • Using the flat end of a spudger to disconnect the motherboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. Huawei Union Screen Replacement: passo 7, imagem 1 %32
    • Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
    Pergunte ao FixBot
    Comentar
  8. Huawei Union Screen Replacement: passo 8, imagem 1 %32 Huawei Union Screen Replacement: passo 8, imagem 2 %32
    • Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
    Pergunte ao FixBot
    Comentar
  9. Huawei Union Screen Replacement, Screen: passo 9, imagem 1 %32
    • Using an iOpener heat source tool, warm the screen of the phone to loosen adhesive of the screen.
    Pergunte ao FixBot
    Comentar
  10. Huawei Union Screen Replacement: passo 10, imagem 1 %32 Huawei Union Screen Replacement: passo 10, imagem 2 %32
    • Wedge an opening pick underneath the screen and slowly work your way around the screen.
    Pergunte ao FixBot
    Comentar
  11. Huawei Union Screen Replacement: passo 11, imagem 1 %32 Huawei Union Screen Replacement: passo 11, imagem 2 %32
    • Using multiple Opening Picks, work your way around the edges making sure not to place too much pressure at any one point.
    • With each pass, move the Opening Pick further to complete separation.
    Pergunte ao FixBot
    Comentar
  12. Huawei Union Screen Replacement: passo 12, imagem 1 %32 Huawei Union Screen Replacement: passo 12, imagem 2 %32 Huawei Union Screen Replacement: passo 12, imagem 3 %32
    • Once screen is sufficiently separated, holding the sides of the frame firmly, use the Spudger to press through the small access window to the screen at the top let and completely separate the screen from the frame.
    • Do not push too firmly. Screen may break. If screen will not separate, use iOpener heating element again and start over.
    • Do not press too far when separating the screen. There is a small ribbon cable attached to the screen that must be gently drawn through small access window.
    Pergunte ao FixBot
    Comentar
  13. Huawei Union Screen Replacement: passo 13, imagem 1 %32
    • Pull screen away from frame making sure the ribbon cable stays attached.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Brittany Achor
Membro desde: 02/14/18
756 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G1, Nance Spring 2018 Membro de USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 886
