Introdução
Use this guide to replace the display including the frame of your Huawei P9 Lite.
Also, take a look at the comments in the last two steps, they might come in handy depending on your replacement part.
O que você precisa
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Remove the nine Phillips #00 screws that secure the metal shield plate.
39 outras pessoas executaram este guia.
7 comentários
I finished to replace the display yesterday and everything is perfect , thanks ifixit
i replaced the display but the touchscreen doesn’t work
You can try to reopen the phone and check if the flex cable is plugged in correctly or if any cable is ripped. If you can’t find any damage and all cables are plugged in correctly it’s possibly an issue with the replacement part.
Hi, could you show how to replace the power button flex cable for a P9 Lite 2017? I would be greatful.
my powerbutton connection is also missing…
