Ir para o conteúdo principal
Huawei P9 Lite Display Replacement
O que você precisa
  1. Huawei P9 Lite Display Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P9 Lite Display Replacement, Back Cover: passo 1, imagem 2 %32
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Display Replacement: passo 2, imagem 1 %32
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Display Replacement: passo 3, imagem 1 %32
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Display Replacement, Loudspeaker: passo 4, imagem 1 %32 Huawei P9 Lite Display Replacement, Loudspeaker: passo 4, imagem 2 %32 Huawei P9 Lite Display Replacement, Loudspeaker: passo 4, imagem 3 %32
    • On the bottom of the phone remove the following screws:
    • Three 2.9 mm Phillips #00 screws
    • Four 3.8 mm Phillips #00 screws
    • Now you can grab the loudspeaker unit and take it out.
  5. Huawei P9 Lite Display Replacement, Motherboard Shield: passo 5, imagem 1 %32
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  6. Huawei P9 Lite Display Replacement: passo 6, imagem 1 %32 Huawei P9 Lite Display Replacement: passo 6, imagem 2 %32
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
  7. Huawei P9 Lite Display Replacement, Battery: passo 7, imagem 1 %32 Huawei P9 Lite Display Replacement, Battery: passo 7, imagem 2 %32 Huawei P9 Lite Display Replacement, Battery: passo 7, imagem 3 %32
    • Disconnect the motherboard flex cable on both ends and take it away.
  8. Huawei P9 Lite Display Replacement: passo 8, imagem 1 %32 Huawei P9 Lite Display Replacement: passo 8, imagem 2 %32
    • Peel off the NFC antenna from the battery.
    • Be careful not to rip or crease the antenna.
    • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
    • Unplug the battery connector.
  9. Huawei P9 Lite Display Replacement: passo 9, imagem 1 %32 Huawei P9 Lite Display Replacement: passo 9, imagem 2 %32 Huawei P9 Lite Display Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    Tesa 61395 Tape
    $8.95
    • Slide the spudger under the battery at the place shown in the picture and pry it loose slowly.
    • Avoid bending the battery and reheat if necessary.
    • Be careful not to damage the display flex cable that runs underneath the battery in the center.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
  10. Huawei P9 Lite Display Replacement, Display: passo 10, imagem 1 %32 Huawei P9 Lite Display Replacement, Display: passo 10, imagem 2 %32
    • Take the flat end of a spudger to disconnect the display flex cable.
    • Flip the phone over and use an iOpener to soften the adhesive at the edge of the display.
  11. Huawei P9 Lite Display Replacement: passo 11, imagem 1 %32 Huawei P9 Lite Display Replacement: passo 11, imagem 2 %32 Huawei P9 Lite Display Replacement: passo 11, imagem 3 %32
    • With a suction handle you can lift the display a little bit to create a gap.
    • Insert just the tip of an opening pick in the gap and steadily slide it along the edge towards the top. You may need to go back and forth a few times.
    • Try to get around the corner and behind the top part of the display. Re-position the suction handle if needed.
    • Leave the opening pick behind the display to avoid the re-sealing of the adhesive.
  12. Huawei P9 Lite Display Replacement: passo 12, imagem 1 %32 Huawei P9 Lite Display Replacement: passo 12, imagem 2 %32 Huawei P9 Lite Display Replacement: passo 12, imagem 3 %32
    • Heat up the iOpener once again and place it on the display to soften the adhesive at the top.
    • Use a second opening pick to slide along the top edge towards the next corner.
  13. Huawei P9 Lite Display Replacement: passo 13, imagem 1 %32 Huawei P9 Lite Display Replacement: passo 13, imagem 2 %32 Huawei P9 Lite Display Replacement: passo 13, imagem 3 %32
    • As long as the adhesive is warm try to continue to separate the display along the side towards the bottom. Re-heat the iOpener if necessary.
    • Don't overheat the iOpener. Stick to the iOpener instructions.
    • Also heat up the bottom part of the display for the next few steps.
  14. Huawei P9 Lite Display Replacement: passo 14, imagem 1 %32 Huawei P9 Lite Display Replacement: passo 14, imagem 2 %32 Huawei P9 Lite Display Replacement: passo 14, imagem 3 %32
    • When you worked your way around the display, take a suction handle and lift the top part of the display away from the frame.
    • Slowly but steadily hinge open the bottom part of the display separating the adhesive.
    • Now you can thread the display flex cable through the gap in the frame.
    • When installing the new display make sure to reapply adhesive where necessary.
Conclusão
26 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
133.015 Reputação
Autoria de 189 guias
Equipe
3Comentários do guia
About release battery ... fishing braided line works better :) battery taken without any destruction.
Slawomir Z. - Responder Compartilhar
Grazie a questa guida ho potuto sostituire batteria e schermo da me. Grazie!
themafiakiller1967 - Responder Compartilhar
Non si può sostituire solo il vetro? X forza anche lcd?
feliciemanuele - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 101
Ao todo: 28,899
