Ir para o conteúdo principal
Huawei P8 Lite Motherboard Replacement
O que você precisa
  1. Huawei P8 Lite Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the SIM card tray.
    • Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
  2. Huawei P8 Lite Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the back cover.
    • The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
  3. Huawei P8 Lite Motherboard Replacement: passo 3, imagem 1 %32
    • Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
    • PH000 Bit
    • T5 Torx
  4. Huawei P8 Lite Motherboard Replacement: passo 4, imagem 1 %32
    • Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
    • These connectors are extremely fragile, so avoid using any kind of tools and make sure to be extremely gentle in the process.
  5. Huawei P8 Lite Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the motherboard carefully.
    • Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
Conclusão
8 outras pessoas executaram este guia.
Brayden Mann
Membro desde: 02/05/16
645 Reputação
Autoria de 4 guias
Equipe
Metro State, Team 1-2, Carpenter Spring 2016 Membro de Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 Membros
Autoria de 8 guias
4 comentários
Anywhere to buy this motherboard? Maybe display as well?
Jan Šinkovec - Responder
mine also need a new mother
anywr l can get it asap
blessed - Responder
Hey
I need p8 lite motherboard
goitsemodimo - Responder
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
Alvaro Gomes - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 17
Ao todo: 8,210
