Ir para o conteúdo principal
Huawei P8 Battery Replacement
O que você precisa
  1. Huawei P8 Battery Replacement, Huawei P8 Battery Replacement: passo 1, imagem 1 %32 Huawei P8 Battery Replacement, Huawei P8 Battery Replacement: passo 1, imagem 2 %32
    • First switch off your phone.
    • Remove the trays for the SD card and the SIM card.
  2. Huawei P8 Battery Replacement: passo 2, imagem 1 %32
    • Remove the two Torx T2 screws located at the bottom next to the device's Micro USB port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shards and get a better grip to open the phone.
  3. Huawei P8 Battery Replacement: passo 3, imagem 1 %32 Huawei P8 Battery Replacement: passo 3, imagem 2 %32
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
  4. Huawei P8 Battery Replacement: passo 4, imagem 1 %32
    • Remove the two Phillips #00 screws that secure the front camera and display/battery connector brackets
  5. Huawei P8 Battery Replacement: passo 5, imagem 1 %32 Huawei P8 Battery Replacement: passo 5, imagem 2 %32 Huawei P8 Battery Replacement: passo 5, imagem 3 %32
    • Use a tweezer to remove the bracket covering the display and the battery flex connector.
    • Unplug the battery flex connector with a Spudger.
    • Remove the bracket covering the flex connector of the front camera.
  6. Huawei P8 Battery Replacement: passo 6, imagem 1 %32 Huawei P8 Battery Replacement: passo 6, imagem 2 %32 Huawei P8 Battery Replacement: passo 6, imagem 3 %32
    • Unplug the headphone jack and the front camera flex connectors.
    • Remove the front camera.
  7. Huawei P8 Battery Replacement: passo 7, imagem 1 %32 Huawei P8 Battery Replacement: passo 7, imagem 2 %32
    • Use a spudger to disconnect the power/volume cable and fold it out of the way.
    • Remove the liquid contact indicator.
  8. Huawei P8 Battery Replacement: passo 8, imagem 1 %32
    • Remove the five Phillips #00 screws that hold down the motherboard of your Huawei P8.
  9. Huawei P8 Battery Replacement: passo 9, imagem 1 %32 Huawei P8 Battery Replacement: passo 9, imagem 2 %32
    • Unplug the vibration motor flex connector.
    • Disconnect the antenna cable.
  10. Huawei P8 Battery Replacement: passo 10, imagem 1 %32 Huawei P8 Battery Replacement: passo 10, imagem 2 %32 Huawei P8 Battery Replacement: passo 10, imagem 3 %32
    • Unplug the display flex connector from the main board with a Spudger.
    • Disconnect and remove the antenna cable with a tweezer.
  11. Huawei P8 Battery Replacement: passo 11, imagem 1 %32
    • Remove the motherboard from the phone.
  12. Huawei P8 Battery Replacement: passo 12, imagem 1 %32 Huawei P8 Battery Replacement: passo 12, imagem 2 %32
    • Carefully peel up the flex cable of your loudspeaker.
    • If the cable is difficult to peel, heat the loudspeaker assembly with an iOpener or a heat gun.
    • Lift up the loudspeaker assembly with a spudger and remove it.
  13. Huawei P8 Battery Replacement: passo 13, imagem 1 %32 Huawei P8 Battery Replacement: passo 13, imagem 2 %32
    • Free the end of the first adhesive pull tab to get a good grip on it.
    • Pull the adhesive tab in a slow constant movement to free the battery.
  14. Huawei P8 Battery Replacement: passo 14, imagem 1 %32 Huawei P8 Battery Replacement: passo 14, imagem 2 %32
    • Free the end of the second adhesive pull tab.
    • Pull the adhesive tab in a slow constant movement.
    • Should those adhesive tabs snap, you might want to use an iOpener to heat and soften them a little bit so you can pry out the battery with a spudger.
  15. Huawei P8 Battery Replacement: passo 15, imagem 1 %32 Huawei P8 Battery Replacement: passo 15, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Tesa 61395 Tape
    $5.99
    Comprar
Conclusão
18 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
204.379 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.299 guias
9 comentários
Really helpful guide. Only hiccup was that on my handset the screws holding the casing together (Step 2) were Torx 2 rather than pentalobe, possibly a regional variation. I opted not to remove the loudspeaker (Step 10) as the ribbon cable was firmly stuck down and I worried it would break. This meant I could only cleanly remove the adhesive pad in line with the charging port. I was able to prise out the battery using spudger and screwdriver to scrape the other pad from the phone body. All now reassembled and working properly!
Ben Raphael - Responder
Overall a very helpful guide . I also had torx screws in mine . The torx screws are tiny , so make sure you have the right screwdriver before starting . We didn’t bother removing the loudspeader assembly either (Step 10) . You can just prise up the ribbon cable (carefully) . Add heat if necessary . Now to the biggest problem . Removing the old battery from the phone . What a nightmare ! It’s really stuck down .We took our time using a hairdryer (no heat gun) , and a flat head screwdriver , and went from one end to the other prising it off gently . It still took about 20 minutes . Saying that . Don’t rush it , as it’s the final stage . Also . If you do use a flat head screwdriver then don’t twist it , as you might damage the casing . Just slide it underneath it applying heat . Total time to remove the old battery was 90 minutes , but about 50 of those were spent just getting the first 2 screws out . 20 minutes to put the new battery in and reassemble . Make sure all flex connectors are properly reseated .
Paul - Responder
My P8 battery has completely died on me. I cannot believe that to replace a battery, we have to now go to these lengths to do it. There must be a mountain of mobile phones, where the only issue with them is a flat battery. Surely, this cannot be allowed to continue. I know why the manufacturers want to make it hard to simply replace a battery, because it sells more mobile phones. But think of all that wasted technology, where a phone may have lasted just over a 24 month contract before the battery is done.
joeninetee - Responder
Many thanks for this tutorial. Together we shall beat them!
Thank you for a very nice and easy to follow tutorial!
I have now replaced my battery with what should be an original battery for the Huawei Ascend P8, battery nr: HB3447A9EBW. For some reason the width of the new battery is a few millimeters smaller than the old one, meaning that it does not fill out the space completely. Has anyone else experienced the same?
After having assembled the phone again I experience some weird issues with the battery level dropping from 50%, 60%, 70% or even 100% in an instant. I have tried calibrating the battery by, letting it die completely, recharge it to 100% let it drain completely again and recharge. I have tried different battery calibration apps and a factory reset - nothing helps.
I contacted the company I bought the battery from and got a replacement - still same issue.
Unfortunately i damaged the original battery when taking it out, so i cant use that as a reference.
Any suggestions would be most appreciated!
Kris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 86
Duração total: 39,229
