Introdução
Use this guide to remove the rear glass on your Huawei P40 Pro.
You’ll need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Apply a heated iOpener to the rear glass to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom edge of the rear glass, as close to the curved edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an iMac opening wheel into the gap.
Slide the opening wheel to the bottom left corner to slice the adhesive.
Insert an opening pick into the gap between rear glass and frame at the bottom left corner of your phone to prevent the adhesive from resealing.
Reinsert the opening wheel at the bottom edge of the rear glass.
Slide the opening wheel to the bottom right corner to slice the adhesive.
Insert an opening pick underneath the bottom right corner of the rear glass, next to the opening wheel to prevent the adhesive from resealing.
Insert the opening wheel underneath the bottom left corner of the rear glass.
Slide the opening wheel along the left edge of your Huawei P40 Pro to cut the adhesive.
Insert an opening pick underneath the top left corner of the rear glass, next to the opening wheel to prevent the adhesive from resealing.
Insert the opening wheel underneath the top left corner of the rear glass.
Slide the opening wheel along the top edge of your phone to cut the adhesive.
Insert an opening pick underneath the top right corner of the rear glass, next to the opening wheel to prevent the adhesive from resealing
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Secure the rear glass with pre-cut adhesive or double-sided adhesive tape during reassembly.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
