Ir para o conteúdo principal
Huawei P30 Pro Charging Port with Main Flex Cable Replacement
O que você precisa
  1. Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Rear Glass: passo 1, imagem 1 %32
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 2, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 2, imagem 2 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 2, imagem 3 %32
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 3, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 3, imagem 2 %32
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 4, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 4, imagem 2 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 4, imagem 3 %32
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 5, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 5, imagem 2 %32
    • If the adhesive becomes hard to cut, it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 6, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 6, imagem 2 %32
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 7, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 7, imagem 2 %32
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Motherboard Cover with NFC & Charging Coil: passo 8, imagem 1 %32
    • Remove the ten Phillips #00 screws (4.3 mm length).
  9. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 9, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 9, imagem 2 %32
    • Slide an opening pick under the black adhesive at the bottom right of the charging coil.
    • Carefully loosen the adhesive with the opening pick.
  10. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 10, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 10, imagem 2 %32
    • Slide an opening pick under the black adhesive at the bottom left of the charging coil.
  11. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 11, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 11, imagem 2 %32
    • Slide an opening pick under the left side of the motherboard cover.
    • Unhinge the left side of the motherboard cover by slightly rotating the opening pick.
  12. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 12, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 12, imagem 2 %32
    • Push the motherboard cover out of the sockets at the top edge of the phone beginning with the top left corner.
    • Remove the motherboard cover including the NFC and charging coil.
  13. Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Battery Disconnect: passo 13, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Battery Disconnect: passo 13, imagem 2 %32
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  14. Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Daughterboard Cover: passo 14, imagem 1 %32
    • Remove the five Phillips #00 screws (4.3 mm length).
    • Some of these screws may be hidden under adhesive. Carefully peel the adhesive to uncover these screws.
  15. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 15, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 15, imagem 2 %32
    • Slide an opening pick under the top edge of the daughterboard cover.
    • Pry up and unhinge the daughterboard cover by slightly rotating the opening pick.
  16. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 16, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 16, imagem 2 %32
    • Remove the daughterboard cover.
  17. Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Main Flex Cable Connectors: passo 17, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Main Flex Cable Connectors: passo 17, imagem 2 %32
    • Use a spudger to pry up and disconnect the left main flex cable connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 18, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 18, imagem 2 %32
    • Use a spudger to pry up and disconnect the right main flex cable connector from the motherboard.
  19. Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Charging Port with Main Flex Cable: passo 19, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement, Charging Port with Main Flex Cable: passo 19, imagem 2 %32
    • Use a spudger to pry up and disconnect the main flex cable connector from the daughterboard.
  20. Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 20, imagem 1 %32 Huawei P30 Pro Charging Port with Main Flex Cable Replacement: passo 20, imagem 2 %32
    • Remove the main flex cable including the charging port by lifting it upwards and then pulling it in the direction of the motherboard.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
7 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
210.056 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
6 comentários
Hello.
I try to change my loudspeaker but wifi signal (if i’m correct about the name) cable is different.
For my phone is that small white cable and i can find only some other kind of cable.
Any idea?
xarishewii - Responder
stimmt das wenn mann das ladebuchse austauscht das der akku nicht mehr so wie früher lädt???
Mthn1903 - Responder
Mir ist der Stecker auf der Hauptplatine (Schritt 17) kaput gegangen, was kann ich tun?
Intuitivmedia - Responder
Nun kann man aber die USB-Buchse plus Haoutflachbandkabel in "Version A" und in "Version D" bestellen. Lässt sich irgendwie vorher herausfinden, welche Version man braucht? Also bevor das Telefon aufgeschraubt vor einem liegt und da dann liegenbleiben muss bis das Ersatzteil da ist?
Besten Dank.
Orkimedes - Responder
Hallo, habe gerade dieselbe Frage. Schon was herausgefunden? Meine Vermutung liegt bei unterschiedlichen Märkten, dass z.B. Europa eine Version benutzt und eine andere Region dementsprechend die Andere, aber das ist natürlich nur eine Behauptung.
Besten Dank
Vedad Ibragic -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 67
Últimos 30 dias: 250
Duração total: 15,030
