Ir para o conteúdo principal
Huawei P10 Plus Headphone Jack Replacement
O que você precisa
  1. Huawei P10 Plus Headphone Jack Replacement, Display: passo 1, imagem 1 %32 Huawei P10 Plus Headphone Jack Replacement, Display: passo 1, imagem 2 %32 Huawei P10 Plus Headphone Jack Replacement, Display: passo 1, imagem 3 %32
    • Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
    • Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
    • To avoid damage to the display, do not push the tool too deeply into the phone.
  2. Huawei P10 Plus Headphone Jack Replacement: passo 2, imagem 1 %32 Huawei P10 Plus Headphone Jack Replacement: passo 2, imagem 2 %32 Huawei P10 Plus Headphone Jack Replacement: passo 2, imagem 3 %32
    • There is a thin display cable between the screen and phone, be very careful not to rip it when opening the device.
    • Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
    • Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
  3. Huawei P10 Plus Headphone Jack Replacement, Unfasten the screw: passo 3, imagem 1 %32
    • Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
  4. Huawei P10 Plus Headphone Jack Replacement: passo 4, imagem 1 %32 Huawei P10 Plus Headphone Jack Replacement: passo 4, imagem 2 %32 Huawei P10 Plus Headphone Jack Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Tesa 61395 Tape
    $5.99
    Comprar
    • Open the metal bracket that covers the display flex cable.
    • Use a spudger to disconnect the display flex cable.
    • Remove the display.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
  5. Huawei P10 Plus Headphone Jack Replacement, Midframe: passo 5, imagem 1 %32 Huawei P10 Plus Headphone Jack Replacement, Midframe: passo 5, imagem 2 %32
    • Remove the 13 Phillips #00 screws.
    • Remove the metal shield which holds down the display flex connector.
  6. Huawei P10 Plus Headphone Jack Replacement: passo 6, imagem 1 %32 Huawei P10 Plus Headphone Jack Replacement: passo 6, imagem 2 %32 Huawei P10 Plus Headphone Jack Replacement: passo 6, imagem 3 %32
    • Remove the SIM card tray.
    • Use the pointed end of a spudger to pry out the mid frame until you can get a good grip.
  7. Huawei P10 Plus Headphone Jack Replacement: passo 7, imagem 1 %32 Huawei P10 Plus Headphone Jack Replacement: passo 7, imagem 2 %32 Huawei P10 Plus Headphone Jack Replacement: passo 7, imagem 3 %32
    • Remove the mid frame.
    • Disconnect the battery flex cable with a spudger.
  8. Huawei P10 Plus Headphone Jack Replacement, Headphone Jack: passo 8, imagem 1 %32 Huawei P10 Plus Headphone Jack Replacement, Headphone Jack: passo 8, imagem 2 %32 Huawei P10 Plus Headphone Jack Replacement, Headphone Jack: passo 8, imagem 3 %32
    • Disconnect the headphone jack flex cable with a spudger.
    • Use an iOpener to loosen the adhesive beneath the headphone jack.
    • Remove the headphone jack.
    • If your new part doesn't include the rubber gasket, you need to transfer it from your old headphone jack to the new one.
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Uma outra pessoa concluiu este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
203.329 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 916
