Ir para o conteúdo principal
Huawei P10 Lite Loudspeaker / Vibration Motor Replacement
O que você precisa
  1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: passo 1, imagem 1 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: passo 1, imagem 2 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: passo 1, imagem 3 %32
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 2, imagem 1 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 2, imagem 2 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 2, imagem 3 %32
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 3, imagem 1 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 4, imagem 1 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 4, imagem 2 %32
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: passo 5, imagem 1 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: passo 5, imagem 2 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: passo 5, imagem 3 %32
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Loudspeaker / Vibration Motor: passo 6, imagem 1 %32
    • Remove the seven Philipps #000 screws.
  7. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 7, imagem 1 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 7, imagem 2 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 7, imagem 3 %32
    • Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
    • Grab the loudspeaker unit and remove it.
  8. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 8, imagem 1 %32 Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: passo 8, imagem 2 %32
    • Use an iOpener to loosen the glue under the vibration motor.
    • Remove the vibration motor.
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
3 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
246.823 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.638 guias
1Comentário do guia
is it necessary to disconnect the finger print sensor flex cable in order to remove/replace the loudspeaker, or is just a precaution!?
Ricardo Mendes - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 4,664
