Ir para o conteúdo principal
Huawei P10 Lite Headphone Jack Replacement
O que você precisa
  1. Huawei P10 Lite Headphone Jack Replacement, Back cover: passo 1, imagem 1 %32 Huawei P10 Lite Headphone Jack Replacement, Back cover: passo 1, imagem 2 %32 Huawei P10 Lite Headphone Jack Replacement, Back cover: passo 1, imagem 3 %32
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Headphone Jack Replacement: passo 2, imagem 1 %32 Huawei P10 Lite Headphone Jack Replacement: passo 2, imagem 2 %32 Huawei P10 Lite Headphone Jack Replacement: passo 2, imagem 3 %32
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Headphone Jack Replacement: passo 3, imagem 1 %32 Huawei P10 Lite Headphone Jack Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Headphone Jack Replacement: passo 4, imagem 1 %32 Huawei P10 Lite Headphone Jack Replacement: passo 4, imagem 2 %32
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: passo 5, imagem 1 %32 Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: passo 5, imagem 2 %32 Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: passo 5, imagem 3 %32
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Headphone Jack Replacement, Headphone Jack: passo 6, imagem 1 %32 Huawei P10 Lite Headphone Jack Replacement, Headphone Jack: passo 6, imagem 2 %32
    • Use the flat end of a spuder to disconnect the headphone jack flex cable.
    • Altough the headphone jack is not glued to the mid frame it is a little bit tucked in its bracket. Be careful not to damage it during the removal.
    • Remove the headphone jack.
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
Membro desde: 11/23/16
211.758 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.077 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 3,394
