Introdução
Use this Guide to disconnect the battery of you Huawei P10 Lite smartphone.
Peças
Nenhum componente especificado.
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
Remove the Phillips screw holding the battery connector plate in place.
Remove the battery connector plate.
Use the flat end of a spudger to disconnect the battery flex cable.
Quase terminado!
Conclusão
