Introdução
Use this guide to replace the back cover of your Huawei P10 Lite.
O que você precisa
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
15 outras pessoas executaram este guia.
6 comentários
You need to warm the adhesive so it can be loose
Nice guide! Thanks! I got a little question about the coloring of the back panel. What kind of coloring is it? Is it a coating you can take off, or is it more like a layer of paint you can scrape off? I am wondering, because I want to clear the back of my Huawei P10 lite. I hope it’s possible though.
